Home > Technical > Instrument Panel problem |
RRSCruiser Member Since: 02 Apr 2010 Location: West Sussex Posts: 41 |
Hi
Sun Jun 10 2018 12:23pm |
One last thing, if you get to replacing the cluster then search on the old LR number, rather than the new number LR has recently given to all these parts. This number is usually on a sticker on the cluster, mine was YAC502190
Sun Jun 10 2018 12:30pm |
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 |
Hi
Mon Jun 11 2018 12:03am |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 |
The version number is a good point, I asked exactly that question in another post... "I am looking to swap out my 2007 Range Rover Sport L320 Diesel MPH Speedo Instrument Speedometer YAC502190 There is a used one for sale but has the HW Version number: YAC500445 Will this fit, or do I have to buy one with the exact same HW Version number ?" So I could fit an earlier version, which like you say are listing a bit cheaper. I would be re-flashing it with my current instrument cluster CCF anyway I think. RRS 2.7 HSE Stornoway Grey P38 4.6 HSE V8 |
Mon Jun 11 2018 8:54am |
Hi, Pal don't by a used one as this can cause other problems as it did with mine, in the end, I ended up buying a new one from British Car Parts for about £400.00 and all the problems where resolved, please bear in mind it will need to be reprogrammed!by a specialist
Mon Jun 11 2018 9:01am |
Hi Yes I'm talking about a new one and of the exact same part just a different "newer" LR.... number, that s why i think its a bit of a conjob on parts. I didn't want any other spec from earlier years to avoid any issues. Yep I paid from memory circa 360 + VAT (UK) Specialist reprogrammed mine, but Phil at GAP quoted the IID will reflash/transfer the cars CCF into new or used cluster. Its on the menus but never needed to try it |
Tue Jun 12 2018 6:57am |
Replacement cluster fitted and problems with flashing hazard lights, doors locking/unlocking, radio switching off all gone now RRS 2.7 HSE Stornoway Grey
Fri Jul 20 2018 11:15am |
Shazlee007 Member Since: 11 Aug 2020 Location: London Posts: 1 |
Hi Looks Dash needs repair. We do RR Dash repair with these common issues at very reasonable prices. PM me please. |
Tue Aug 11 2020 9:46am |
HF-Martini Member Since: 09 Jul 2021 Location: Cambridgeshire Posts: 8 |
That’s a brilliant and perfectly concise guide on how to do a full fault find, top marks indeed, helped me out no end.
Fri Jul 23 2021 6:09am |
