![]() | Home > Technical > Cant seem to calibrate my suspension? |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Good morning Spencer,
lamb190 Member Since: 12 Jun 2015 Location: bristol Posts: 80 ![]() ![]() ![]() |
To be honest i dont "set it to tight tolerance" i just adjust each corner as instructed in suspension calibration.
Re-tight mode i have just read the guide and it is not required for the calibration so don't worry about that.
Ok will check this.
Hi Spencer, how have you got on with this? |
Ive been too busy to check again. But will check corner voltages asap. The car is sitting ok at a glance. But will check as i think i set the rear to -7
Ok, I would set the height adjust to normal and then calibrate the suspension. Once you have calibrated then use the height adjust function to lower to your preferred height. |
This is what i did before (setting height to normal) i will try and have a play tomorrow. |
