![]() | Home > Faults & Fixes > Slow Acceleration form standstill then Surge ! |
I assume it’s a 3.0 SDV6? 2019 5.0 SC SVA (Current)
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Indeed it is |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 ![]() ![]() ![]() |
Yes it’s characteristic of the car and super annoying when pulling out into busy traffic. A remap would fix it... Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
My sdv6 was like this at first. The old "roundabout" hesitation was the worst. Do you hold your breath and go for it or just try to time your arrival so as not to stop ?
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
My 62 plate sdv6 is like this and from what I have read that is normal unless it had a remap.
Maca Member Since: 26 May 2018 Location: Wigan Posts: 1 ![]() ![]() |
my 2015 Range rover Td6 i had remapped
Td6 ? Are we talking about a Sdv6 sport as TD6 was the old straight 6 they used in a vogue.
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 908 ![]() ![]() |
Mine does this as well. You think you have plenty time at roundabouts, |
See my post above. |
Was the remap specifically aimed at this problem ? or was it done for general increase in power ? |
It was aimed at better general driveability and at least the ability for better mpg. Power and torque increases are relatively modest at circa 20 percent, and merely take the mk1 to broadly the same outputs as mk2, so no concerns about overstressing engine, gearbox or driveline components.
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 ![]() ![]() ![]() |
My 2012 suffered horrendous delay, until I had a full service and used wynns extreme clean. Seems my injectors were bunged up.
I run the wynns through a couple of times a year and generally dose with millers each fill up. |
