Home > Faults & Fixes > Slow Acceleration form standstill then Surge ! |
I assume it’s a 3.0 SDV6? 2019 5.0 SC SVA (Current)
Fri Jun 08 2018 2:31pm |
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 |
Indeed it is |
Fri Jun 08 2018 2:34pm |
hoppy_70 Member Since: 28 Mar 2009 Location: United Kingdom Posts: 437 |
Yes it’s characteristic of the car and super annoying when pulling out into busy traffic. A remap would fix it... Range Rover Sport HSE DYnamic SDV6 Velocity blue 2020 MY
Fri Jun 08 2018 5:50pm |
My sdv6 was like this at first. The old "roundabout" hesitation was the worst. Do you hold your breath and go for it or just try to time your arrival so as not to stop ?
Sat Jun 09 2018 7:32am |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 |
My 62 plate sdv6 is like this and from what I have read that is normal unless it had a remap.
Sat Jun 09 2018 7:58am |
Maca Member Since: 26 May 2018 Location: Wigan Posts: 1 |
my 2015 Range rover Td6 i had remapped
Tue Jul 10 2018 8:21pm |
Td6 ? Are we talking about a Sdv6 sport as TD6 was the old straight 6 they used in a vogue.
Tue Jul 10 2018 8:25pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 911 |
Mine does this as well. You think you have plenty time at roundabouts, then suddenly the car coming round is nearly on top of you, then the power kicks in, very disconcerting. I welcome any info on a fix. |
Wed Jul 11 2018 9:30am |
See my post above. |
Wed Jul 11 2018 10:26am |
Was the remap specifically aimed at this problem ? or was it done for general increase in power ? |
Wed Jul 11 2018 10:30am |
It was aimed at better general driveability and at least the ability for better mpg. Power and torque increases are relatively modest at circa 20 percent, and merely take the mk1 to broadly the same outputs as mk2, so no concerns about overstressing engine, gearbox or driveline components.
Wed Jul 11 2018 11:21am |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 440 |
My 2012 suffered horrendous delay, until I had a full service and used wynns extreme clean. Seems my injectors were bunged up.
Wed Jul 11 2018 8:11pm |
I run the wynns through a couple of times a year and generally dose with millers each fill up. |
Wed Jul 11 2018 8:12pm |
