Home > General > ENGINE LIGHT ON LOW POWER
Harveyp500
United Kingdom 2009 Range Rover Sport 3.0 TDV6 HSE Santorini Black
HI GUYS
Quote:
Have a 2009 Sport 2.7hse that is running low on power, engine light is on and has no pull, gets to around 50mph and struggles to go more. Starts and ticks over fine, not lumpy, revs fine, no smoke what so ever, temperature sits at normal. I am thinking a turbo issue but thought turbo failure comes with a good smoke? So could do with some ideas on where to start please guys. Mileage is 131k, always been serviced and never had any issues with her.
Hello,
Finally got her looked at, but was done while away so at this point only have the garage report so could do with some advice on whether what is detailed on the means "NEW TURBO" report is saying "turbo actuator fault logged in memory" checked vehicle on ramp and found turbo VNT mechanism seized, requires new turbo!
I am not saying that I have an issue with the garage, I just like to know if what the report is saying is the fact or there is another option such as turbo actuators or rods, before I stump up a couple of grand or more to have the turbo changed.
Cheers 2023 D350 FIRST EDITION, SANTORINI WITH CLOUD/EBONY
2024 DEFENDER D250 110 HSE APACHE
2009 2.7 TDV6 HSE SANTORINI BLACK
GONE
2020 RRS P400e AUTOGRAPHY
2018 3.0 SDV6 AUTOBIOGRAPHY, CARPATHIAN GREY, SANTORINI PAN ROOF, IVORY INTERIOR. Now gone but will be missed, Cracking motor.
2015 3.0 SDv6 HSE DYNAMIC CORRIS
2014 3.0 SDV6 HSE FUJI WHITE CONTRAST SANTORINI PAN ROOF.
Evoque 2.2 d Pure Tech Auto
P38 4.0 HSE
Disco 2.5 d XS
Post #560892 Fri Jul 06 2018 10:52pm
geoffsnook
Turbo actuator may be sticking but get a code read done to be sure Thumbs Up
Post #560899 Sat Jul 07 2018 8:26am
Brit Plumber
^^^^ What he Said ^^^^ 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #560906 Sat Jul 07 2018 9:32am
Brit Plumber
This may be of use,
I think this shows the software driven self check to help prevent a seized actuator. 2019 5.0 SC SVA (Current)
Post #560907 Sat Jul 07 2018 9:37am
Harveyp500
Thanks for the advice, hopefully that's it, looks like i can do it myself avoiding the labour charges. Will be having a look tonight when i get home so will keep you posted.
Thanks again
Harvo 2023 D350 FIRST EDITION, SANTORINI WITH CLOUD/EBONY
GONE
P38 4.0 HSE
Disco 2.5 d XS
Post #560984 Mon Jul 09 2018 9:02am
Harveyp500
Hello,
GONE
P38 4.0 HSE
Disco 2.5 d XS
Post #563771 Wed Aug 22 2018 11:15pm
geoffsnook
The actuators are known to stick so maybe yours is are they land rover specialist's or a normal garage as if not land rover they may just want to change it and not free it off maybe you need to ask the question or get more info off them Thumbs Up
Post #563778 Thu Aug 23 2018 8:51am
Harveyp500
Local indy, i have had other makes previously where turbos have failed and this sport shows none of the characteristics of a failed turbo that i have seen before except for being down on power, even the engine light is no longer lit!!
I will be going back for more info later today, I suppose i have been lucky as this is the first major issue I have had with the LR/RR I have had in 22 years of owning them and with the cost of replacing the turbo I want to be sure that this is the issue and not the actuators or rods. 2023 D350 FIRST EDITION, SANTORINI WITH CLOUD/EBONY
GONE
P38 4.0 HSE
Disco 2.5 d XS
Post #563794 Thu Aug 23 2018 1:37pm
