![]() | Home > General > ENGINE LIGHT ON LOW POWER |
Turbo actuator may be sticking but get a code read done to be sure |
^^^^ What he Said ^^^^ 2019 5.0 SC SVA (Current)
This may be of use,
Harveyp500 Member Since: 08 Mar 2016 Location: Worcester Posts: 58 ![]() ![]() ![]() |
Thanks for the advice, hopefully that's it, looks like i can do it myself avoiding the labour charges. Will be having a look tonight when i get home so will keep you posted.
The actuators are known to stick so maybe yours is are they land rover specialist's or a normal garage as if not land rover they may just want to change it and not free it off maybe you need to ask the question or get more info off them |
Local indy, i have had other makes previously where turbos have failed and this sport shows none of the characteristics of a failed turbo that i have seen before except for being down on power, even the engine light is no longer lit!!
