![]() | Home > Technical > Squeaking at low speed |
Dry putting your foot on the brake lightly as you drive along and see if the squeak goes off. If it does then the brakes need servicing.. 2008 G4 RRSport TDV8 current
Wayneclarke Member Since: 16 Jun 2014 Location: kent Posts: 394 ![]() ![]() ![]() |
Ok thanks I will try that when I'm next in the car |
Could be a hub carrier bearing - the one at the top and bottom of the upright that the wishbones connect to. Mine has had this on both rears in the last 6 months. Only noticeable when the window is down and speed is low. New bush sorts it. 2012 SDV6 - it's missing a couple of cylinders
yeah i have to have the window down to hear it |
If you rock the car when it's parked can you hear the squeak? 2012 SDV6 - it's missing a couple of cylinders
squeal disappears when i put my foot on the brake |
As I said on an earlier reply the brakes need seviceing 2008 G4 RRSport TDV8 current
nice one camelrock i will get them done |
kttlaweb Member Since: 08 Aug 2016 Location: Derbyshire Posts: 16 ![]() ![]() ![]() |
Sorry to revive an old topic, I have the same issue, however as described above...when I bounce the car (or rock it) I hear the bloody annoying squeak - It sounds like an old bed...Where would be a good place to start? |
Rear hub bushes - the ones that link the rear uprights to the wishbones. 2012 SDV6 - it's missing a couple of cylinders
