Home > Technical > Squeaking at low speed
Wayneclarke
Had the window open today and when i was going slow or letting off the gas i could hear a squeak.? Any ideas guys
Post #496897 Tue May 24 2016 11:40am
Camelrock
Dry putting your foot on the brake lightly as you drive along and see if the squeak goes off. If it does then the brakes need servicing.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #496902 Tue May 24 2016 12:38pm
Wayneclarke
Ok thanks I will try that when I'm next in the car
Post #496919 Tue May 24 2016 3:28pm
Could be a hub carrier bearing - the one at the top and bottom of the upright that the wishbones connect to. Mine has had this on both rears in the last 6 months. Only noticeable when the window is down and speed is low. New bush sorts it. 2012 SDV6 - it's missing a couple of cylinders
Post #496957 Tue May 24 2016 8:17pm
Wayneclarke
yeah i have to have the window down to hear it
Post #496958 Tue May 24 2016 8:28pm
If you rock the car when it's parked can you hear the squeak? 2012 SDV6 - it's missing a couple of cylinders
Post #497024 Wed May 25 2016 8:40pm
Wayneclarke
squeal disappears when i put my foot on the brake
Post #502726 Sat Aug 13 2016 1:03pm
Camelrock
As I said on an earlier reply the brakes need seviceing 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #502781 Sun Aug 14 2016 7:21am
Wayneclarke
nice one camelrock i will get them done Thumbs Up
Post #502782 Sun Aug 14 2016 7:59am
kttlaweb
United Kingdom 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Sorry to revive an old topic, I have the same issue, however as described above...when I bounce the car (or rock it) I hear the bloody annoying squeak - It sounds like an old bed...Where would be a good place to start?
Post #560473 Mon Jul 02 2018 5:59pm
Rear hub bushes - the ones that link the rear uprights to the wishbones. 2012 SDV6 - it's missing a couple of cylinders
Post #560510 Mon Jul 02 2018 8:11pm
