![]() | Home > In Car Electronics > Advice Needed |
OzzyRanger Member Since: 30 May 2018 Location: Brisbane Posts: 1 ![]() ![]() ![]() |
G'Day All,
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
Ozzy - Try a squirt of WD40 into the ignition key hole. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5044 ![]() ![]() ![]() |
Would not advise WD40 in ignition barrel, use a Graphite Powder if it may be sticking as the WD40 will gum it up over time.
I've not known it gum up.
[quote="waynescott523"]Hi guys, I need your help I've bought a 2008 3.6 tdv8 the problem is the screens in the rear headrest are not working (no power at all) also on my navigation screen there is not a rear entertainment option as there should be.there is power in the CD unit under the seat. Any ideas what the problem might be before I have to call out an audio tech guy. Thanks in advance Wayne.[/qu
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 ![]() ![]() |
I used to be a locksmith and I agree with Col. We always used dry graphite powder which will get to the bottom as it's very frictionless (same as rubbing a graphite pencil on a squeaky door hinge to silence it). Any wet oil can attract dirt and dust to stick to it, eventually wearing out the internal components of the lock barrel. 2016 RRS SVR Estoril Blue 2005 4.2L Supercharged Java Black - gone but was my first love. -------------------------------------------------------------------------------------------------------- If we all point our RR's in the same direction and accelerate at the same time can we turn back time? |
