Home > Faults & Fixes > 2005 Range Rover sport 4.2 v8 supercharged missfire issue
Shauny0809
Right guys I really need help I’ll start off with I got the car cheap so fort I’d have try to fix if not I’ll break it but hear goes the old owner said it went in for mot and it ran out of fuel and ever since then it has been missfireing and reduced proformance and goes slow up hills or if u put to much gas on it it feels like it’s running out of fuel I had it read 2s now 21 was independent Land Rover said had miss fire so I changed the plugs Still same issue I noticed 1 coilpack had been changed so change that 1 and I know friend who works for Maserati so he did read on his code reader and said had missfire 2468 but when he reved the car I noticed that bits of the cat was coming out of the driver side exhaust and was spitting it all out has I drove home after that I. Didn’t get the engine light on all way home 40miles when got home I got under the car and give it a light tap on the cat and u can here it all broke would this cause the low proformance or is it limp mode causing it I’ve bought new fuel pump and filter for in the tank but not yet fitted as fort with it running out of fuel it might of pulled some shot threw the filter causing it to miss fire. But unsure any body else got any ideas of the symptoms all wat comes up is intermate miss fire on them cylinders if u put ur foot lightly on pedal it will gradually get up to speeds 50mph + if u put it on to soon that’s when seems get missfire and sometimes get a flashing engine light for few seconds I also changed the pcv valve for new 1 as fort it was leaking as can hear a hiss so changed that and still can hear it but not sure weather it’s ment to be like that thanks
Post #558517 Fri Jun 08 2018 8:17pm
Brit Plumber
If it ran out of fuel it may be a fuel pump but it sounds like the cat may have collapsed and blocked the silencers. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #558518 Fri Jun 08 2018 8:37pm
Shauny0809
Would that cause missfire the drivers side cat is defiantly broke and I can hear big piece rattling and it can’t get past the bend on the exhaust
Post #558520 Fri Jun 08 2018 8:47pm
Tim in Scotland
The emissions controls will be trying to adjust the mixture to get the emissions right which is probably why you have the misfire. Sounds like you will need two new cats as given the age of the car the other side might be worn out if unburned fuel has gone down it. It might cost more than the car is worth to rectify the problem as replacement cats are not cheap. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #558536 Sat Jun 09 2018 6:46am
Shauny0809
Yea the cats are exspensive but was thinking of getting the cats gutted out for now to see if it improves maybe see if like a gd mapper can alter the difference with out them in or something
Post #558546 Sat Jun 09 2018 8:01am
yeah I was thinking that.
remove the CAT, knock the inside out the best you can till bits stop coming out.
remove the rest of the exhaust, to get bits out.
refit and drive, see what its like
Post #558547 Sat Jun 09 2018 8:25am
Shauny0809
Yea think that be best bet every car I’ve owned have had no cats due to being decated etc on my Subaru’s so any see why it much a difference for this as still petrol end of day
Post #558552 Sat Jun 09 2018 9:01am
geoffsnook
C an you get some decat pipes made for it and see if that works Thumbs Up
Post #558561 Sat Jun 09 2018 11:24am
Shauny0809
Happy happy the passenger side cat was blocked and broke she’s running perfect now thanks
Post #558632 Sun Jun 10 2018 7:00pm
gutted both cats ?
Post #558640 Sun Jun 10 2018 8:29pm
Shauny0809
Yea I gutted the drivers side as that was the 1 wat was making a noise still was same after gutted it so I changed pump and filter today and that didn’t work so got Censored off and was gonna break it until I fort I’ll just do the other side and as I was cutting into it it was like sand trickling out all the cat and half was blocked up etc. But I think Iknow the actual cause why it had done it when I did the pump there was only 1 pipe connected to the filter witch didn’t take any notice of until I installed the new 1 we had pipe not connected to anything so who ever done it hadn’t connected the pipe properly I don’t think to the filter hence the missfires to cause cats to go bad and then that caused bad cats so after reinstalling pump was same reduced proformance until I gutted the other cat and now she runs perfect and sounds awesome 😎 only problem I have now is there’s piece cat in the last centre box witch might have chopped out and straight pipes done to it oh and noticed my centre prop shaft bearing has gone so looking for tips on how replace that and if an easy inuf job thanks for all ur help thow
Post #558643 Sun Jun 10 2018 9:05pm
lucky you.
bet you didn't pay much for it.
Post #558677 Mon Jun 11 2018 11:10am
