Home > General > Turbo replacement - cost
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
Can anyone give me a guide as to what I can expect the quote to be from a UK Land Rover dealership garage for replacing the turbo on a 2006 Sport? I am in France and expecting a quote from my local dealership and I'm wondering how it might differ from a UK garage. Andrew Kennedy
Post #557996 Sat Jun 02 2018 2:22pm
Expensive.
Body needs lifting to do it easily.
Post #558009 Sat Jun 02 2018 6:02pm
nebc100
Luxembourg 2008 Range Rover Sport TDV6 HSE Java Black
I have never done it, but I have read that it can be done through the wheel arch, but not easy.
Post #558011 Sat Jun 02 2018 8:00pm
Oldandconfused
Is it actually the turbo that has failed? The reason I ask is that a sticking variable vane actuator is a common problem resulting in reduced performance. There is an updated part to rectify this and i understand it can be done with the body on. A lot of owners have managed to free it off using a bit of wire and grease. Worth looking into initially.
Post #558013 Sat Jun 02 2018 8:56pm
The experts say it can be done easily in 10 hours lifting body.
Or painfully in 10 hours not lifting it.
So if u have a post lift, lift it.
Post #558016 Sat Jun 02 2018 10:02pm
Father Jack
Scotland 2012 Range Rover Sport SDV6 HSE Santorini Black
£3.7k for an sdv6 though that is both turbos and a body off job. Indy price. Should be less for 1 turbo even at main dealer prices as the turbos alone are around £1200 each for Garrats.
Post #558019 Sat Jun 02 2018 11:17pm
Oldandconfused
Have a look at this
https://www.disco3.co.uk/forum/topic97892....p;start=15
I make the assumption that you have had the codes read. It may be helpful to post them on here as people may be able to suggest what they mean.
Post #558024 Sun Jun 03 2018 7:18am
andrew kennedy
Unfortunately I can't give the codes as the garage hasn't given them to me. After they carried out the diagnostic (for which they didn't give me a bill - which leads me to feel they didn't find a problem and they don't want to take any responsibility). All they did say was they thought it was the turbo causing the problem of the ENGINE SYSTEM FAULT message showing on the dash - they sent me on my way saying come back if the warning comes up again. It's a 2006 Sport and hasn't done 100,000 miles. The guy who usually looks after servicing for me gave me a Censored and told me to PUT YOUR FOOD DOWN MORE OFTEN which I do now and use a better grade of diesel.....any other thoughts as to how I can try to fee up the turbo gratefully received!!!  Andrew Kennedy
Post #558044 Sun Jun 03 2018 2:29pm
PDC
My turbo failed last year with only 15k on my Disco, which is the same vehicle as the Sport. Luckily it's still under warranty otherwise it would have cost me 6k and they did lift the body the change the turbo.... 2010 RR 5.0 Autobiography
2020 F-Pace SV
2018 RRS HSE Dynamic 3.0
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #558061 Sun Jun 03 2018 8:12pm
you don't want to be changing the turbo, if it "might be the turbo".
Check how free the actuator rod is
Post #558070 Sun Jun 03 2018 8:34pm
andrew kennedy
Oldandconfused wrote:
Have a look at this
Thanks for yours!! I've had a look at the video - it's something I would certainly like to have-a-go-at. Would you say the car needs to be up on a lift, or possibly could be done by crawling under the car?!? Andrew Kennedy
Post #558120 Mon Jun 04 2018 3:48pm
Oldandconfused
Iv'e never had the need to do it myself, thankfully. If access is via the wheel arch, I imagine jack that corner up, axle stand under the chassis rail, wheel off and get stuck in. I would think that it would be a lot easier if you have access to a lift though.
Post #558149 Mon Jun 04 2018 10:11pm
Yes exactly as above.
I have heard of people doing it only with the suspension set to off road height (and maybe the steering on full lock)
however the first time I would guess you want to wheel off to try and find the rod. (it's not easy)
Post #558175 Tue Jun 05 2018 11:03am
faby2020
France 2008 Range Rover Sport TDV8 HSE Alaska White
Good morning,
I just saw you post and even if it's a bit older I wanted to ask you some infos.
I'm in the same situation you were few years ago, I also live in France.
where you able to find a good and honest mechanic capable to replace your turbo/s ?
Your answer would be very helpful as I'm having hard time finding one.
Thank you.
F.
Post #606331 Fri Nov 06 2020 3:22pm
