![]() | Home > General (L494) > Extended height mode |
You have to fool the underbody sensor into thinking that you are about to bottom out the car................ With L320 RRS you could do this from access mode but I have no idea how you can achieve this with L494/ RRS2 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1176 ![]() ![]() ![]() |
also wondering about this, although I have an IID tool to do this --
anyone? --
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
Apparently you can't manually do this - only the car does it automatically if you are |
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
syl posted this link on another thread that touched on the same question:
hmm, I more wanted to know what is the safe extra height that I can program using my IID tool? --
Don’t, is the simple answer - the suspension components are designed to run normally at the two set heights - normal and offroad. Even in offroad height it is recommended that on cross slopes to lower to normal or if safe to access height to lower the Centre of Gravity of the car, even more important if you are offroad with a roof tent and all that extra weight as it could cause a roll over.
Tim, this is just for off-road.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
Tim, where did you hear about the ARB behaviour? What you describe with the rear ARB sounds like the D2 ACE system. My understanding of the RRS system is that it does not do it that way. Both ARBs behave as if they are disconnected at low speed on the RRS dynamic response system but the ARB doesn't actively force the wheel down - the air suspension does that using the cross link valves and the ARB does not try to stop it as it would on road. The D3/4 do the same but the ARB is not disconnected because it's a traditional bar. 2012 SDV6 - it's missing a couple of cylinders
It was shown way back in 2005 on Top Gear when the car was launched 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Top Gear. Mmmm...
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
Yes I remember Hammond's comments on the L320, they were rediculous!
V8tdi Member Since: 30 Apr 2017 Location: Powys Posts: 70 ![]() ![]() ![]() |
When I was on the Land Rover experience day in dunkeld they did it in a sport I was driving If I remember he put it in access height while we were in a track and it sensed it was touching the ground and went into extreme height mode It stayed in that until you went over 10 mph Not sure how you do it otherwise but it’s pretty cool and you are are really high Ken |
Well, it's very easy to add extra height with the IID tool.
