Home > Maintenance & Modifications > RRS 3.6TDV8 Exhaust Mods
Cymruambyth
Wales
You should do a sound clip / video Thumbs Up Steve.
Post #553485 Sun Apr 08 2018 10:48am
d-9
glennp123 wrote:
Well i took the backboxes off yesterday it was just the right difference made that i wanted. Doesnt sit idling like a tractor. Just a nice deeper tone to the way it was factory. But its when you get up the rev range and you get to really hear that v8 sound! Sounds just like an american v8 petrol!
So in conclusion if you have the TDV8 ....Do this!!
Do you still have your mid box?
Post #553586 Sun Apr 08 2018 10:09pm
chopperneil
United Kingdom 2009 Range Rover Sport TDV8 HSE Java Black
what did you remove and what did you replace it with? always wanted a fruitier sound from my TDV8
Post #553621 Mon Apr 09 2018 11:53am
Westinghouse
Removed the centre box on mine, so it's just essentially piework from the cats back now right to the exit.
On tickover, it's got a nice deep throbbing V8 sound, akain to an English Electric CS12V engine. Driving round town it's noticeable, but subtle and then when you want to get a shift on it sounds superb for a diesel!
The bore of the pipework you'll need is 54mm πŸ‘
Post #556897 Sat May 19 2018 1:28pm
d-9
How is it at 50/70/80?
Post #557021 Sun May 20 2018 10:13pm
Westinghouse
Zero drone and zero intrusion in to the cabin when cruising at any speeds πŸ‘
Post #557028 Mon May 21 2018 5:47am
d-9
Perfect, thankyou
Post #557045 Mon May 21 2018 8:54am
Westinghouse
No problem. This is on a TDV8, the turbos and cats offer good sound deadening and resonance reduction.
On a petrol V8, you might want to keep the small rear silencers on each side if you’re removing the center boxes and also add an X-pipe to balance the exhaust πŸ‘
Post #557071 Mon May 21 2018 12:06pm
d-9
Mine is also a TDv8, I was planning on leaving the back pipes as they are only resonators, and replacing the mid-box with straight pipes.
Post #557084 Mon May 21 2018 2:47pm
