![]() | Home > Maintenance & Modifications > RRS 3.6TDV8 Exhaust Mods |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
You should do a sound clip / video |
chopperneil Member Since: 25 Aug 2015 Location: Kent Posts: 55 ![]() ![]() ![]() |
what did you remove and what did you replace it with? always wanted a fruitier sound from my TDV8 |
Westinghouse Member Since: 15 Apr 2018 Location: West Yorkshire Posts: 6 ![]() ![]() ![]() |
Removed the centre box on mine, so it's just essentially piework from the cats back now right to the exit.
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
How is it at 50/70/80? |
Zero drone and zero intrusion in to the cabin when cruising at any speeds π |
Perfect, thankyou |
No problem. This is on a TDV8, the turbos and cats offer good sound deadening and resonance reduction.
Mine is also a TDv8, I was planning on leaving the back pipes as they are only resonators, and replacing the mid-box with straight pipes. |
