![]() | Home > General > Fault codes on car |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5066 ![]() ![]() ![]() |
Those codes are incomplete there should be another two digits on the end, however
Gibson Member Since: 17 Feb 2017 Location: Washington Posts: 39 ![]() ![]() ![]() |
Cheers Colin are these easy to fix or is it a indy job |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
What issues are you having with the car? |
This is the one related to suspension.
Yellow suspension light then the red one and car drops onto its arse and shakes your fillings out |
C1A20 is a lack of air pressure when filling the reservoir
Thank you Mikey your a star how do you go about fixing wiring issues is it new parts or strip and clean joins etc ? |
Start by finding the broken wire, and either repair if possible, or overlay with new wiring |
Cheers steering went heavy a few weeks ago but went light again |
