Home > General > Fault codes on car
Gibson
Fault codes on car
Hi guys I've been having suspension problems on my rrs 05 so I bought a lr2 icarsoft scanner and I have these faults but have tried Google etc and can't seem to get any answers here's the codes if anyone knowledgable could help me it would be massively appreciated
C1A55
C1A20
C1122
Many thanks
Post #556936 Sun May 20 2018 8:50am
Those codes are incomplete there should be another two digits on the end, however
C1A55 Ignition Switch Input Circuit
C1A20 Pressure Increase to Slow Filling Reservoir
C1122 Steering Isolation Valve
Post #556938 Sun May 20 2018 9:06am
Gibson
Cheers Colin are these easy to fix or is it a indy job
Post #556940 Sun May 20 2018 9:21am
Disco_Mikey
What issues are you having with the car?
Post #556941 Sun May 20 2018 9:25am
This is the one related to suspension.
C1A2064 Pressure Increase
Too Slow When
Filling Reservoir.
Compressor fault.
Reservoir pipe air leak.
Reservoir air leak.
Gallery pipe air leak.
Intake filter
blocked/restricted.
Intake pipe
blocked/restricted.
Air suspension intake
silencer blocked/restricted.
Corner valve stuck open.
Pressure sensor fault.
Refer to the guided diagnostic routine for this code on the
approved diagnostic system. Check the Air suspension intake pipe
and silencer for blockage/restriction.
Post #556942 Sun May 20 2018 9:28am
Gibson
Yellow suspension light then the red one and car drops onto its arse and shakes your fillings out Very Happy thanks for replying guys
Post #556949 Sun May 20 2018 11:55am
Disco_Mikey
C1A20 is a lack of air pressure when filling the reservoir
Either a worn compressor or leaking air tank are the most common issues
C1122 is a wiring issue to the valve in the steering rack. Guessing your power steering is fairly heavy most of the time?
C1A55 is usually an EPB related code, wiring issue in the NSR arch is the issue 99% of the time
Post #556950 Sun May 20 2018 12:31pm
Gibson
Thank you Mikey your a star how do you go about fixing wiring issues is it new parts or strip and clean joins etc ?
Post #556951 Sun May 20 2018 12:49pm
Disco_Mikey
Start by finding the broken wire, and either repair if possible, or overlay with new wiring
Post #556953 Sun May 20 2018 1:02pm
Gibson
Cheers steering went heavy a few weeks ago but went light again
Post #556955 Sun May 20 2018 1:08pm
