![]() | Home > Maintenance & Modifications > EGR blanking and new MOT rules |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5037 ![]() ![]() ![]() |
too early to say, but you may as well get it thru this years MOT first
They can not visually inspect, so if they see blanking plates (assuming they know what they’re looking for) then it may be a fail.
Should read:
Begs the question, when will they be able to plug into the vehicle diagnostics to see if the EGR's are functioning |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
As above. Visual inspection only.
They were talking about checking for ECU fault codes last year (or year before) and for checking for chipped cars, but didn't get introduced yet |
Zeoman Member Since: 24 Sep 2017 Location: EH181DF Posts: 39 ![]() ![]() ![]() |
So, I have a fresh mot and I want to blank my egr. I have seen 2 kits on eBay. One 2 piece and a 4 piece which has some seals fitted. I want to leave pipework in place. Also, on viewing the howto list I saw butterfly removal. May I ask the reason for this please?
2 piece is more than sufficient |
wilf Member Since: 08 Nov 2012 Location: on the naughty step Posts: 939 ![]() |
While we are on the subject of MOT testing - does the stop/start system get checked at all? MY2016 HSE D SDV6 - gone due to fuel dilution problems.
If they start checking for chipped cars where would that leave me with my Alive reprogrammed ecu ? And the rest of us with similar mods ? |
Not at present ![]() |
Not an issue at the moment, and not one that I can see even in the future. Too many variables and unknowns, and I expect a workaround would also be possible if the worst were to happen ![]() |
Cheers Mikey. Always appreciate you taking the time to post so often here and on the Disco site. Especially when you've got a busy garage to run. |
DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240 ![]() ![]() ![]() |
If I decide to blank the EGR's on my EU4 07 plate do I have the specific patching software loaded on my IID Tool or do I have to purchase a software patch from GAP or other? |
