smurtaza
I do have access to a lift and it took couple of hours to remove the module. It is pretty tight in there but I believe it could be done on a driveway, if you put RR on extended height. But to release the cables you need to remove the rare brake rotors and for that back wheels have to come off. Most time was spent on removing rotors, releasing cables from left/right shoes, emergency cable under the shifter area and just removing all the hangers to get the cables free. Module comes out from the passenger wheel arch.
I have seen a youtube video of a guy taking the module cover off while still in the car but I was not able to get to the screws on the cover (space was too tight) I think he was working on LR3 (may have more space on LR3). Plus the module cover is glued on and even after getting it out, it took some effort to pry it off. I don't think I would have been able to get the cover off while on the car, even if I got the screws off.
Once the module is out of the car, you can unscrew and pry the cover off. To test the it, unplug the motor connections and you can test the mechanism by providing 12V to the motor connections. Be careful, a straight battery connection provides up to 600+ AMPS and could run the motor really fast and pull the cables to the stop and break the transmission. I used a testing tool that puts out 30-50 AMPS and trips on anything over that power.
Reversing the polarity runs the motor in reverse, so you can play with it pulling and pushing the cables. There is a youtube video showing how to remove the cables from the pulling mechanism and remove the motor/transmission out of the module (not every hard to do). Opening up the motor was the hardest part and I was not sure if that would even work. Back cover of the motor has crimped tabs that had to be pried to get the back cover off. Putting it back on was pretty easy.
Putting the transmission cogs back in the right order was a little challenging but not too bad. The whole module fix took around 2 hours.
I now have another issue to deal with. After removing the brake module, (with the module out) I tried to start the car and now I have flashing hazards, bunch of errors (transmission failure, transfer case errors, etc...) and no start. I hope putting the module back will sort the issues, otherwise I believe there are some wires in the back that sometimes get shorted out and RR computers go nuts (battery is putting out 13+ Volts). Will cross that bridge when I get there.
But at least now I know how the parking brake mechanism works and what are the things that could go wrong it with.
Thu May 03 2018 3:04pm |
