![]() | Home > General (L494) > Anyone hardwired a dashcam in L494? |
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
The installer I used (near Brighton, Sussex) also found it very difficult to know how to get the wire for the rear camera (Lukas Qvia AR970) from within the roof space to the rear window. Eventually they found that, due to the tailgate being effectively a one piece plastic moulding they had to remove the rear roof spoiler (the bit with the shark aerial on it), and then feed the wire up through one of the two large rubber conduit tubes and then down in to the top of the tailgate. They had to drill one hole in to the window surround, but I am happy with the result. The attached photo (very poor lighting) is when the tailgate is open & up, looking from the rear towards the front of the car. The tailgate is the top 2/3rds of the picture, with the inside top of the rear window at the top of the image.
Humbug Member Since: 01 Aug 2014 Location: East Anglia Posts: 48 ![]() ![]() |
My installer had no trouble getting the wire over to the bootlid – I didn't watch him but it didn't take long and he definitely didn't remove any trim or use his drill and it's very unobtrusive.
udash Member Since: 16 Oct 2009 Location: manchester Posts: 196 ![]() ![]() |
This looks neat, I think the wire comes along one of the hinges and then comes down, I am not sure if the wire gets trapped by the weather seal when the door closes, but I guess due to the way seal is fitted water should not come in. |
RR Ally Member Since: 28 Nov 2015 Location: Kings Lynn Posts: 65 ![]() ![]() |
Thanks everyone,
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
I have just hardwired in a Thinkware X550.
doug97gxe Member Since: 29 Jul 2017 Location: CT Posts: 2 ![]() ![]() |
i just registered with the sole purpose of thanking you for creating this post.. it helped me tremendously in installing my dashcam |
You're welcome. Glad it helped |
Pakolainen Member Since: 14 Mar 2016 Location: Helsinki Posts: 310 ![]() ![]() ![]() |
Finally gotaround to installing the front camera of the Blackvue 650. Therear camera will be for a ither day.
Has anyone managed to wire their dash cam into the fuse box behind the glove box,in the l494,their must be a constant live & ignition live in there somewhere.
That was my first plan, to have it all in the glove box instead of routing one cable from the boot to the windscreen and then the rear cameras cable from windscreen to tailgate. However the space to work with on the glove box fuses is quite tight. and there's no real place to store all the gubbins that come with the Power Pro Magic. - they can of course go in the glove box but it requires a bit of drilling or cutting to get the wires neatly through.
arwV8 Member Since: 17 Feb 2018 Location: Worcestershire Posts: 18 ![]() ![]() ![]() |
I'm wiring in one at the moment, and this is what I have mapped out on the passenger compartment fuse panel behind the glove box on my 2016 TDV8
jd2uk Member Since: 01 Apr 2017 Location: Kent Posts: 109 ![]() ![]() |
For those of you that have completed your own dash cam installation, what do you make of this installation? Looks pretty good to me?
BigBen Member Since: 15 Dec 2015 Location: Hertfordshire Posts: 88 ![]() ![]() |
I had my Thinkware professionally fitted and asked if the rear camera could be fitted at the bottom of the screen rather than the usual top position. This is because the top area is more affected by the area not wiped and I didn't want it offset nor visible in my rear view mirror. So it was fitted in the middle of the bottom of the screen and gives great coverage and very unobtrusive (cant see it through rear view mirror). The only visible wiring is a couple of inches from the camera to the plastic trim round the base of the window. The fitter has managed to hide all the wiring and fed it through existing trunking into roof trim so no looped wiring at the top of the boot lid. A very neat job.
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 102 ![]() ![]() |
I found the same blog post while working out how to do mine. I emailed them to ask how to approach the rear camera install, as the door trim seems to be moulded to the rear window. Never hear back, so I'm not that impressed. |
