Home > Maintenance & Modifications > EPB seized on; Wind back shoes? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4944 |
you need to align the adjuster hole with the adjuster, which isn't easy with the brake jammed on! |
Tue Apr 17 2018 11:05am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
, hadn't thought of that. |
Tue Apr 17 2018 11:06am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
Emergency release very rarely works but you should be able to pull on it more than an inch,,, need to put some serious effort into it and see if it will move more. Have had the same issue, dirt and neglect are the big enemy,,, hence the screeching noise when it tries to operate, the module just winds the shoes up tighter and tighter. Even cutting the cables on mine would not release the brakes so I think you stand no chance trying to wind them back. In the end cost me new disc's, pads, shoes etc and module. 2010 RRS, TDV8
Tue Apr 17 2018 4:57pm |
I'm beginning to feel very despondent about this now.
Tue Apr 17 2018 5:26pm |
I REMEMBER WHEN I HAD ISSUES WITH MY DISCOVERY I THOUGHT I WAS GOING TO BREAK IT I PULLED IT SO HARD BUT WHEN YOU SEE THE CABLE PATH YOU UNDERSTAND |
Tue Apr 17 2018 5:46pm |
Ooops did not realise cap's lock was on |
Tue Apr 17 2018 6:00pm |
If you have had the shoes serviced, then Have a look at this :
Tue Apr 17 2018 6:07pm |
Disappointing seeing you had them serviced recently, providing they were done correctly. As Andy has pointed out,, could be a problem with the module itself that is caused the issue. 2010 RRS, TDV8
Wed Apr 18 2018 6:50am |
Local indi has read codes (different post) and pronounced the module Fubar'ed so will need replacing. This was when it was still driveable, just screeching. He was a bit busy so I said i'd bring it back, no rush
Wed Apr 18 2018 8:04am |
If the module had failed, I would have expected the manual release to have worked. Could it not be seized cables? 2019 5.0 SC SVA (Current)
Wed Apr 18 2018 6:23pm |
I am more inclined to discount seized cables as it would auto release, albeit with a screech when driving off. That was before it completely seized that is. |
Wed Apr 18 2018 6:57pm |
I think the emergency release would only work providing the shoes etc are nice and free 2010 RRS, TDV8
Thu Apr 19 2018 6:24am |
You may well be correct. My understanding is that the emergency release actually disengages the cables inside the module from the mechanism that puts them under tension. I would hope that, bearing in mind the brakes were stripped and adjusted in January, the shoes should be free to move.
Thu Apr 19 2018 6:42am |
My thought train was that the manual release may have worked however if the cables are seized, the brake would still be stuck on. My old Mondeo had similar when the protective tube over the inner cable got pulled into the outer Bowden and jammed the brake on on one side. In fact, is it both wheels stuck on or just one? Have you checked? 2019 5.0 SC SVA (Current)
Thu Apr 19 2018 2:56pm |
