![]() | Home > In Car Electronics > Broken Dab arial |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5067 ![]() ![]() ![]() |
I didn't even realise a 06 plate car even have dab radio, thought it came in with the facelift.
doyleywood Member Since: 09 Feb 2018 Location: Rossendale lancashire Posts: 18 ![]() ![]() |
Same here, but the arial defo dab connection. |
Might be worth posting a photo of the damaged plug, could help identify it to see if it can be replaced.
Factory wiring really tight, hard to get the plug to line up square while holding the head unit up close. |
See photos in gallery |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
It's not DAB, but it is very similar to a fakra connector, that plug looks well and truly goosed though.
That is a Fakra plug the colour of it will tell you which one you need, unless you use a sort of Aqua coloured one which is universal fit. As said that will be a real pain to solder and crimp in do in situ. due to limited room I would think.
Oh right, that explains why the plug would not fit the dab unit i was trying to fit, hence the damage! Where could i buy this fitting? |
Could Google Fakra Connector and see what comes up, sure I got some off Amazon in days gone bye or possibly ebay.
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 411 ![]() |
i think martin might sell these in the forum 'shop'.... |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
look for a right angled connector though as a straight may foul something to the rear.. |
May be a pain but if your fitting a DAB head unit, why don’t you fit a dab aerial and save fixing that one? 2019 5.0 SC SVA (Current)
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 ![]() ![]() ![]() |
Agree fit a proper DAB antenna
