Home > In Car Electronics > Broken Dab arial
doyleywood
Broken Dab arial
Just managed to damage the dab arial plug that plugs in to the radio/head unit, it’s a real tight squeeze and I bent the little metal tangs, anyway can the plug be replaced? Anyone know where the dab arial wire gos from the back of the head unit, is there a connection anywhere under the dash, thanks in advance
06 sport SC
Post #553821 Wed Apr 11 2018 8:28pm
I didn't even realise a 06 plate car even have dab radio, thought it came in with the facelift.
Post #553827 Wed Apr 11 2018 9:11pm
doyleywood
Same here, but the arial defo dab connection.
Post #553828 Wed Apr 11 2018 9:20pm
Might be worth posting a photo of the damaged plug, could help identify it to see if it can be replaced.
Post #553832 Wed Apr 11 2018 9:57pm
doyleywood
Factory wiring really tight, hard to get the plug to line up square while holding the head unit up close.
Post #553851 Thu Apr 12 2018 8:47am
doyleywood
See photos in gallery
Post #553857 Thu Apr 12 2018 9:17am
doyleywood
Post #553859 Thu Apr 12 2018 9:44am
Socast
It's not DAB, but it is very similar to a fakra connector, that plug looks well and truly goosed though.
You could cut the damaged plug off and replace it with a new one, its a standard co-ax type wire though so may be a bit of a pig to do neatly and also shield from interference.
Post #553884 Thu Apr 12 2018 12:03pm
That is a Fakra plug the colour of it will tell you which one you need, unless you use a sort of Aqua coloured one which is universal fit. As said that will be a real pain to solder and crimp in do in situ. due to limited room I would think.
Post #553886 Thu Apr 12 2018 12:40pm
doyleywood
Oh right, that explains why the plug would not fit the dab unit i was trying to fit, hence the damage! Where could i buy this fitting?
Post #553887 Thu Apr 12 2018 12:42pm
Could Google Fakra Connector and see what comes up, sure I got some off Amazon in days gone bye or possibly ebay.
Post #553889 Thu Apr 12 2018 12:48pm
scarey
i think martin might sell these in the forum 'shop'....
Post #553901 Thu Apr 12 2018 3:38pm
PC76
look for a right angled connector though as a straight may foul something to the rear..
Post #553921 Thu Apr 12 2018 5:40pm
Brit Plumber
May be a pain but if your fitting a DAB head unit, why don’t you fit a dab aerial and save fixing that one? 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #553936 Thu Apr 12 2018 6:58pm
RobP
Agree fit a proper DAB antenna
This one gives fantastic reception http://www.dabonwheels.co.uk/Kinetic_DRA-6...erial.html TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #554116 Sat Apr 14 2018 12:44am
