Home > General > Won't warm up
Bullnogger
England 2007 Range Rover Sport TDV6 HSE Java Black
Won't warm up
Changed thermostat and coolant
On 2.7 sport gone through bleeding procedure
Twice now temp gauge only goes up a 1/4
Won't go up to halfway on gauge where it use to be
Had heaters on full blast getting hot from heaters
But viscous fan keeps kicking in and out
Is it possible new stat is stuck shut
Thank you for any advice No friends no favours
Post #553663 Mon Apr 09 2018 8:09pm
Eaters
This won’t help much Embarassed but I do seem to remember some other comments on here about warming up and IIRC the solution was a new thermostat. However as you’ve already done that it would be a real Censored if that was the fault. That viscous fan does sound a bit suspect.
I’ll get out of the way now and wait for someone more helpful to point you in the right direction Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #553679 Mon Apr 09 2018 10:07pm
PC76
please don't quote me... as I'm not to sure on how the air con is setup on the RRS...
Did you turn off the air con when the heat was blowing? the aircon would normally start the fan, best to have it switched off if it is an option.
Also are you driving to get the engine warmed up?
Post #553687 Tue Apr 10 2018 12:07am
Bullnogger
Yes drove it over an hour
Temp gauge only up to Quarter way
Used to go half way
Air con off
The way my luck is it will be the
New stat I will replace it again week end
And update in case anyone has this
Problem No friends no favours
Post #553699 Tue Apr 10 2018 10:42am
press the ECO button on the climate control (this shuts the AC Off) and then see if the vicious fan is behaving better, and see if you get an improvmeent
Post #553700 Tue Apr 10 2018 11:06am
Brit Plumber
In my opinion if the thermostat was failed open, it would take a long time to get to temp. If it failed closed it would get Very Hot under load and very quick.
Have you thought about the temp sensor? If you can find it, you could remove it, reattach to the wiring and see if it reads correctly by submerseing it in water from a boiled kettle. You also put a thermometer against a pipe to see what the temp is reading. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #553716 Tue Apr 10 2018 4:26pm
geoffsnook
Mine is doing the same takes what i think is twice as long to warm up have got a new thermostat to go in Thumbs Up
Post #553734 Tue Apr 10 2018 5:43pm
Bullnogger
I pressed eco button and monitored
Fan while idling
Cured fan it stopped comeing on and off
And after about 30 mins idling
Temp gauge sitting where it normally sits
Found out air con empty as well
So I will get it recharged
Ordered a new expansion cap
And stat
I will check temp sensor tonight after work
Thank you to all for thoughts andreplys much appreciated No friends no favours
Post #553765 Wed Apr 11 2018 4:49am
Eaters
Good news Thumbs Up and useful know.
Just make sure your re-charger checks for leaks as you don't want it all to just disappear again. Robin
Gone:
MGZTT 190 2.5
Post #553768 Wed Apr 11 2018 6:16am
Socast
Not to be a smart arse, but the thermostat is closed when cold and opens when hot.
So when the engine is cold the closed thermostat bypasses the radiator and circulates the water round the engine to heat it up faster, then once it reaches the right temp the wax in the thermostat expands forcing it open and allowing the water to be cooled by the radiator. You can test your thermostat is working by dropping it into a cup of boiling water Thumbs Up
My money would be on the sealing ring round the edge of the thermostat being pinched/torn and allowing coolant past it.
Post #553783 Wed Apr 11 2018 1:27pm
Usually story is, for the cost of the thermostat, you may as well replace it if you have it out. But nice to establish a cause.
Thermostat's used to have a small bypass hole, so doubt a sealing gasket would make much of a difference ?
Post #553801 Wed Apr 11 2018 4:47pm
Socast
speaking from experience the seal being torn/failing does keep the engine from getting warm, and that’s on the 4.2. So a diesel would never warm up.
Post #553815 Wed Apr 11 2018 7:00pm
geoffsnook
I did see some where the other day think it was with those Atlantic people and the seals to go a bit Thumbs Up
Post #553816 Wed Apr 11 2018 7:03pm
Bullnogger
The thermostat on the 2.7
Sits below rad with about 6 or 7 hoses
Connecting to it I've put a new water outlet assembly on top
Of engine no stat in there mine split so I opened it up
To see what was in there
Will be replacing thermostat
Rad cap
Check temp sensor
On Sunday due to working Saturday
Will update once done thank you
For all replies brilliant forum No friends no favours
Post #553817 Wed Apr 11 2018 7:05pm
