Home > General > Won't warm up |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1540 |
This won’t help much but I do seem to remember some other comments on here about warming up and IIRC the solution was a new thermostat. However as you’ve already done that it would be a real if that was the fault. That viscous fan does sound a bit suspect.
Mon Apr 09 2018 10:07pm |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 |
please don't quote me... as I'm not to sure on how the air con is setup on the RRS...
Tue Apr 10 2018 12:07am |
Bullnogger Member Since: 29 Mar 2016 Location: Stoke on trent Posts: 81 |
Yes drove it over an hour
Tue Apr 10 2018 10:42am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4966 |
press the ECO button on the climate control (this shuts the AC Off) and then see if the vicious fan is behaving better, and see if you get an improvmeent |
Tue Apr 10 2018 11:06am |
In my opinion if the thermostat was failed open, it would take a long time to get to temp. If it failed closed it would get Very Hot under load and very quick.
Tue Apr 10 2018 4:26pm |
Mine is doing the same takes what i think is twice as long to warm up have got a new thermostat to go in |
Tue Apr 10 2018 5:43pm |
I pressed eco button and monitored
Wed Apr 11 2018 4:49am |
Good news and useful know.
Wed Apr 11 2018 6:16am |
Not to be a smart arse, but the thermostat is closed when cold and opens when hot.
Wed Apr 11 2018 1:27pm |
Usually story is, for the cost of the thermostat, you may as well replace it if you have it out. But nice to establish a cause.
Wed Apr 11 2018 4:47pm |
speaking from experience the seal being torn/failing does keep the engine from getting warm, and that’s on the 4.2. So a diesel would never warm up. |
Wed Apr 11 2018 7:00pm |
I did see some where the other day think it was with those Atlantic people and the seals to go a bit |
Wed Apr 11 2018 7:03pm |
The thermostat on the 2.7
Wed Apr 11 2018 7:05pm |
