![]() | Home > Maintenance & Modifications > EPB fault Code C1A46-64 |
There doesn't seem to be a fault code C1A46-64 perhaps you mis-typed?
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
Properly confused now. I have a print out which says "DTC viewer" and those are the codes. Mine is the mk1 facelift but I shouldn't have thought it would make any difference.
OK, after a deep breath, this may help;
Release is under the EPB switch,,, a bit difficult to see as it's only a metal cable with a loop in the end. I hope you have more luck than I did as they very rarely work,,,, so I was informed by my indie 2010 RRS, TDV8
gogsy, how do you get to the wire loop? I can't see how to remove the switch. |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
OAC, its under the centre cup holders apparently according to my handbook... (now i know I'm getting old)
Much appreciated, I will have a look later this morning (I did look in the handbook but couldn't find it |
Mine is under the EPB switch,, didn't have to remove the cup holders. Prise off the gaiter round the gearstick and there are 2 screws that hold in the EPB switch. Take it out and with the aid of a flashlight you should be able to spot the loop on the cable end. Use the handle off your jack to hook the cable and give it a good tug,, should move a few inches. 2010 RRS, TDV8
haven't got round to this yet, will report back thanks. |
Quick update;
The switch should come out,,, might just want a little persuasion. There's not much room to get hold of the cable which is why you need something strong with a hook on the end. 2010 RRS, TDV8
Hmmm...emergency release, not so much emergency than if you carry a full tool kit you maybe able to get it released lol |
EPB module has now been replaced by Ian at Fenland 4X4 and everything now hunky-dory. I am just waiting for RAC warranty to reimburse me the cost, which should be OK as they have authorised the payment.
