![]() | Home > General > Fuel Question. |
Hutch41 Member Since: 19 Nov 2016 Location: Northumberland Posts: 95 ![]() ![]() ![]() |
I always fill up with Shell V-Power Diesel but it is quite expensive.
That's what I suspected ... do you use the cheaper fuel ? |
The only difference is the 'brands' add their own particular additives at the depot These additives can increase the 'burn' and help clean injectors (both petrol and diesel). I use Supermarket fuel but every 5/6 refills I use a tank of Shell/ BP. |
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
I use the supermarket pumps if it's handy at the time but just as often use the regular big petro company forecourts. |
wilchesth Member Since: 11 Mar 2018 Location: Falmouth Posts: 41 ![]() ![]() ![]() |
I always find that buying from my local asda pump gives me less miles to the gallon compared to when I fill in my esso garage where it is usually 2p per litre more expensive. I can get roughly 20 ish miles more on a full tank. Or it might be all in my head |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 591 ![]() ![]() |
As has been said above the additive pack in Premium fuel is way better than supermarket fuel - hence why supermarket fuel is cheaper - my advice would be to stick with Premium branded fuel for better MPG and a better all round driving experience .
Quite often it’s an esso tanker that fills our local Tesco’s. 2019 5.0 SC SVA (Current)
I work for one of the major fuel and lube companies and know exactly what goes on |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Let’s just make sure we are comparing like with like. Yes there are standards covering the basic fuel so I can’t see that Tesco standard fuel is any different from Esso standard fuel.
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I found that on the last couple of cars I`ve had, I`ve had slightly better mpg with Tesco Momentum. If I can`t be bothered going across town to Tesco, I just use normal Shell unleaded.
HughN Member Since: 10 Sep 2017 Location: Near Llanybydder Posts: 651 ![]() ![]() |
I'd read that as all fuels across Europe meet the minimum standards - it doesn't mean the big companies can't include additives to exceed those standards. |
Can't beat insider knowledge so I will defer to you ![]() |
