Home > Maintenance & Modifications > Interior trim swap/colour change
Bustanut
Replaced interior trim with black this evening. I’m really chuffed with the results.
Post #553100 Tue Apr 03 2018 8:07pm
Wayneclarke
looks lovely Thumbs Up
Post #553103 Tue Apr 03 2018 8:15pm
Evo5man
United Kingdom 2013 Range Rover Sport SDV6 HSE Lux Orkney Grey
Re: Interior trim swap/colour change
[quote="Bustanut"]Replaced interior trim with black this evening. I’m really chuffed with the results.
Looks great Thumbs Up
How easy is it to change the centre console trims? Looks like a big job, does the whole console need to come out?
Post #553125 Tue Apr 03 2018 9:40pm
Bustanut
Thanks Evo5man. The door trim can be done in about 10 mins, really easy. The console is a bit more in depth, you have to undo two screws behind the CD slot (which pops out), remove the gear lever (put in drive, depress the button and pull up), then use some panel removal tools (set can be purchased for £10 from euro car parts) to pull up the top part of the concole (where the trim starts). Then you need to disconnect the two plug connectors and it lifts up at the back and out. I then took the console into the garage and stripped it down to fit the side trims. If you are reasonably handy its easy enough to do. I plan to wrap my old trims in the same colour and sell them on. Thinking about it i should have done a video for youttube as there isnt a lot on there for this specific job. If you plan to do it feel free to ask questions.
Post #553151 Wed Apr 04 2018 10:45am
Bustanut
Thanks
Post #553152 Wed Apr 04 2018 10:45am
Evo5man
Hi Bustanut, thanks for the reply and info. One of the centre console side trims in my car is scratched and I'm thinking about changing it. Your info will definitely help me a lot Thumbs Up
Thanks again.
Post #553162 Wed Apr 04 2018 11:56am
Pinnacle
Wow I'm so glad you posted these pictures and mines being changed as we speak and I was a little nervous about whether I'd made the right choice.
Post #553230 Thu Apr 05 2018 10:00am
Bustanut
Pinnacle, are you going with the piano black like mine. I think it brings the interior up to date. The wood is nice but not in this instance. It’s such an easy mod and makes such a difference to the look & feel of the interior. I think a brushed silver could look good too. Possibly with a black interior. Are you doing it yourself?
Post #553237 Thu Apr 05 2018 11:28am
Pinnacle
yes mate, Same as you.
Post #553277 Thu Apr 05 2018 10:09pm
HN54AWS
England 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Where about a did you purchase the trim from? I have the same original wood trim and would like to turn it black.
Post #554298 Mon Apr 16 2018 8:06am
Brit Plumber
I’ve seen powerful U.K. do them and some other bits. They are out of stock on some parts which is typical as my CD player facia must be a nats gonad bent and stops the CD ejecting. I was going to fit a black gloss one but alas they are nil stock. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #554299 Mon Apr 16 2018 8:21am
Bustanut
Came across them on eBay and bought them on impulse. I had decided I was going to change mine to black but was going to wrap them. I will wrap mine in black and list them when I get chance.
Post #554332 Mon Apr 16 2018 6:20pm
jzive
If anyone else thinking of interior trim swap >>
http://www.rrsport.co.uk/forum/topic50691.html
If cares, pls let me know.
Post #554376 Tue Apr 17 2018 7:40am
Bustanut
That looks like a good buy jzive. I paid £150 for just the black trims. If I hadn’t done it already I’d have been all over yours. Good luck with the sale. I d be surprised if they don’t sell quickly.
Post #554424 Tue Apr 17 2018 4:24pm
jzive
thanks. they'll go at some point so not bothered - agreed looking to fleabay you can pay that just for
the wood finish NO hockey sticks! door cards a free option...
Post #554426 Tue Apr 17 2018 4:30pm
