Home > Maintenance & Modifications > EXTERIOR D PILLARS
maci234
EXTERIOR D PILLARS
can anyone help me and tell me what is the cure for your d pillars not digging into the paint as my two have dug into the paint as they don't seem to be sitting straight
Post #552396 Tue Mar 27 2018 11:16am
Meiang
Australia 2010 Range Rover Sport TDV8 HSE Santorini Black
The plastic rear covers cut into the paint on most of the L320 models that I have seen at the top and the bottom closest to the hatch. It appears to be a design fault. I have clearance on the bottom when the car is stationary but have paint wear down to the primer in a small spot. The top has no clearance but has only cut into the clear coat.
Post #552423 Tue Mar 27 2018 5:33pm
maci234
mine has cut right through on the bottom mostly there must be some kind of fix ,can repair the paint for it to happen again
Post #552426 Tue Mar 27 2018 5:39pm
I simply cut a couple of small strips of double sided adhesive 5mm thick high density foam rubber and stuck under lower edge, works perfectly. Can position it to leave same gap as complete lower edge of cover about a 1-2mm gap.
Post #552456 Tue Mar 27 2018 8:36pm
maci234
what tape did you use and how did you position it I tried tape but didn,t work at all have to repair the paint there now you would think there would be an easy fix that the d pillar would fit and stay straight ,thanks
Post #552460 Tue Mar 27 2018 8:47pm
This is all I used, got it of fleabay, been on there 2/3 years now and no marks on paint whatsoever.
Post #552462 Tue Mar 27 2018 9:04pm
maci234
ok will have to go back to the drawing board again to see if I can figure something out that will last
Post #552463 Tue Mar 27 2018 9:06pm
Meiang
I assume one needs to remove the plastic rear cover to fit the rubber strip.
Post #552488 Wed Mar 28 2018 8:18am
maci234
do you have a link for the double sided adhesive 5mm thick high density foam rubber
Post #552500 Wed Mar 28 2018 10:09am
maci234
do you have a link for that
Post #552525 Wed Mar 28 2018 3:28pm
As it was so long ago e-bay have deleted the original purchase history, however it would have been something like this.
https://www.ebay.co.uk/itm/ADHESIVE-BACK-N...1924661448
Post #552567 Wed Mar 28 2018 9:20pm
maci234
thanks a lot
Post #552568 Wed Mar 28 2018 9:22pm
