Home > Technical > Help brembo calipers/alloys
RRSV8
Hi guys
Need some help please, got some new wheels for my rrs tdv8 2007 with brembo calipers on front
& new wheels are very close to calipers almost scraping
New alloys are 22"x10.5j et 38
What size spacer would be best to clear calipers 3-5mm ?
Thanks
Post #552366 Mon Mar 26 2018 7:08pm
Tyrefitter
As long as they aren’t catching their is nothing to worry about.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #552370 Mon Mar 26 2018 7:42pm
RRSV8
Thanks for reply, they are catching slightly so don't want to risk driving etc
will def need some spaces, will try 5mm.
Post #552376 Mon Mar 26 2018 9:45pm
Cymruambyth
Wales
I have 22`s with Brembos with no issues. Shouldn`t need spacers. Steve.
Post #552380 Tue Mar 27 2018 12:28am
Buckster
Maybe he is using the larger 6 pot Brembos? 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #552384 Tue Mar 27 2018 6:21am
jzive
6pot brembo upgrade recently done (calipers/disks a L494 take-off) to 2010 TDV8 running standard 20s with no issues whatsoever. with brakes/feel considerably more responsive than standard.
Post #552390 Tue Mar 27 2018 10:12am
PDC
3mm clearance will be enough and as a rule of thumb run with the minimum thickness spacer you can get away with..... Thumbs Up 2010 RR 5.0 Autobiography
2020 F-Pace SV
2018 RRS HSE Dynamic 3.0
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #552400 Tue Mar 27 2018 12:03pm
RRSV8
Just to update tried 5mm spacers, new wheels cleared oem 4 pot brembos perfectly
but then the new tapered wheel nuts will only tighten 3-4 threads
so what do i do now ?
try 2/3mm spacers or wheel adaptors ?
new wheels are 22x10.5j et 38 all round
Post #552433 Tue Mar 27 2018 6:46pm
Eaters
This may not help directly but I had real probs with the 19 inch winter wheels I bought for my TDV8. In the end I had to sell them. Did contemplate spacers but was worried about risk of an issue with my insurers. The offset is a key figure in wheel purchase and it became a minefield for me.
Have a read here for more info on my debacle if you feel inclined.
http://www.rrsport.co.uk/forum/topic46913.html Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #552471 Tue Mar 27 2018 10:09pm
PDC
Your next step is to purchase a set of extended wheel nuts and that will solve that particular problem. But as Easter pointed out you have the wrong offset wheel and this will be the only way to correct the problem if you want to keep the rims. 2010 RR 5.0 Autobiography
2020 F-Pace SV
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #552509 Wed Mar 28 2018 12:28pm
RRSV8
What is the correct offset & where can I buy extended nuts from ?
Thanks.
Post #552518 Wed Mar 28 2018 2:30pm
PDC
Have a look eBay for longer wheel nuts, or better still Advance Factor, they are site sponsors. As far as offset, any rim off a 494 should fit as they all run with 6 pot Brembo callipers. Supercharged RRS 1 also ran with 6 pots. Thumbs Up 2010 RR 5.0 Autobiography
2020 F-Pace SV
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #552554 Wed Mar 28 2018 7:13pm
RRSV8
spoke to the company who supplied the new wheels, was told if i want these wheels to fit
they can recess the bolt holes
further down as there is enough metal to make alteration
which should fix the problem.
i will still have to use 5mm spacers to clear brembo calipers
but once they recess the holes, i will be able to tighten wheel nuts to spec
so will this option be safe guys ?
as i really like the wheels & want to keep them
Post #552996 Mon Apr 02 2018 7:37pm
PDC
For the price of a set of wheels nuts I think I would go with that option. I’m not sure I fancy wheel milling option over a new set of nuts. πŸ‘πŸ» 2010 RR 5.0 Autobiography
2020 F-Pace SV
2015 Disco XXV
2011 Disco 3.0
2008 RRS HST V8
Post #553008 Mon Apr 02 2018 10:34pm
Be worth checking what load capacity the wheels have too. Many aftermarket wheels aren't really designed for the weight of a RRS. 2012 SDV6 - it's missing a couple of cylinders
Post #553029 Tue Apr 03 2018 9:40am
