![]() | Home > Orders (L494) > All New Model - When ? |
Autobiography Member Since: 19 Jun 2012 Location: Londres Posts: 339 ![]() |
Range Rover is due to debut in Fall 2020 as a 2021MY. LR May launch the L494 replacement at the same time. |
As above, Range Rover in 2020 but I would think Sport will be replaced a year later as the current one came out a year after FFRR. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Basis current price trends nobody will be able to afford it anyway unless they win the lottery... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
RRSman Member Since: 10 Feb 2015 Location: London Posts: 1439 ![]() ![]() |
It's usually a 7/8 year turnaround. The previous gen was from 2005-2013 and then they launched the L494 in 2013. The new version will probably be seen towards the end of 2020 now. |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 ![]() ![]() ![]() |
So there's only two years left on this current model ?
syl Member Since: 10 Mar 2016 Location: Somerset Posts: 412 ![]() ![]() |
PCP finance (if they offer a decent GMV), or a lease, may be the best way to go then. RRS MY17 SDV6 AB
Yep guess so
Defender in 2018/19, FFRR 2020, RRS 2021, D5 facelift 2022 at a guess. 2012 SDV6 - it's missing a couple of cylinders
You forgot the Evoque coming next year - basically a mini Velar.... |
So if you lot were financing a facelift and know there's a new model coming in 2/3 years tops - how would you finance it, what would make the most sense ?
timhum Member Since: 06 Mar 2017 Location: Suffolk Posts: 389 ![]() ![]() |
I guess your major concern is the future value of the car which is of course protected in a PCP deal but probably will cost more to finance. I would compare all finance options and determine which will cost the least over say a three year period. You then need to make a call on what you believe the fv will, this can be done using the PCP gfv figure as a guide; the finance companies don't make their calculations based on making a loss on the final value of the car. Looking at the finance options available to you determine how much can be saved with the cheapest and that saving will then give some additional protection on the value of the car at th end of your finance period.
When I got mine last year, I looked around and found that if LR are giving a decent discount (and/or PCP contribution) with low rate APR, then PCP can be the way to go, otherwise leasing is cheaper. I got mine via PCP in the end, because they were offering a percent or two off the standard APR and a five figure discount.
It comes to within a few grand of each other really. But PCP seems to edge it out ever so slightly and if I do my sums right I guess PCP could give a small reward at the end.
kismet110 Member Since: 09 Oct 2010 Location: London Posts: 382 ![]() ![]() ![]() |
