![]() | Home > General > Thinking of a 2007 tdv8 |
TDV8 were all HSE and came with the Brembo 4-pot brake calipers up front. The TDV8 (in the UK) also came with adaptive cruise control (ACC) as standard - this is cruise control with radar to maintain a set distance from the car ahead. TDV8 has the dynamic response system as standard too. This is hydraulic anti roll bars front and rear that give better on road handling along with better off road articulation (the anti roll bar acts as if it is effectively disconnected at low speed). I think TDV8 also came with the "fridge" in the front centre arm rest (it's not a true fridge, it's just a cool box but it works well when the engine is running).
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
As RRSTDV8 says in his sign off, they are a labour of love. Wonderful car when going well but it is imperative (just like with any RRS) that you take the time to check all the gizmos work properly. Check the off road options and height adjustments all work and work smoothly without any strange noises
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 316 ![]() ![]() ![]() |
Most important thing with a a tdv8 is service history. The turbos fail somewhere around 100k, lots of other bits and pieces will need replacing over the years. You want one that has been looked after not neglected, or you'll spend the cost of the car again putting it right.
Mani Member Since: 18 Jun 2016 Location: Uxbridge Posts: 298 ![]() ![]() ![]() |
Hi Pal
Steveo1783 Member Since: 13 Mar 2018 Location: Essex Posts: 4 ![]() ![]() |
The one I am looking at has 128k on it so will of the turbos be on there way out and do they just fail or is there any way to check them also do they all fail or is it just bad luck if it fails |
Unless they've been replaced, you should budget to replace them. Pop in to your local independent specialist and get a price for replacing them.
The turbos don't automatically fail. They are susceptible to being abused however. If the driver allows the engine to idle for a minute or two (as one really should with any turbo anyway), then they can go on for a long time. If they're driven hard and just turned off whilst still red hot then they don't last. The engine should always be brought up to temperature before working it hard.
Just a non turbo question are the seats all the same and the leather just some pictures I have seen the leather looks like my old disco 3 with little holes in it and then others that are all smooth leather without the holes |
Afaik all the tdv8s have solid leather, the supercharged have holes.
Nope I didn’t see that I will look now 👍 |
Just to add my 10 cents worth,, I agree with most of the comments made but my V8 has perforated leather and does not have Brembo brakes either,, but the ones fitted still work very well if maintained properly. I can't comment on the difference between the 2 as I have not driven a RS with brembos. 2010 RRS, TDV8
The facelift changed the brakes and seats as well as the rest of the interior. Pre-2010 were solid leather and Brembo front brakes. 2012 SDV6 - it's missing a couple of cylinders
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I wouldn`t even compare my s/c to a sports car, let alone a diesel. They certainly don`t handle like one! Steve. |
