Home > General > Dash-cam for '08 RRS - opinions/recommendations?
Richythepom
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi all,
After a recent close call Shocked ... I'm thinking of getting one of these installed. I quite like the idea of a rear-view-mirror mounted option. Just wondering if anyone's had one of these fitted and if there are any brands/models to look for/avoid, please.
Cheers,
Rich 2008 RRS HSE Stornoway Grey
Post #551091 Mon Mar 12 2018 11:12am
Bill Portland
i use the nextbase 312gw. Have had it for about 2 years and very pleased with it. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #551092 Mon Mar 12 2018 11:54am
Richythepom
Thanks Bill. Any issues fitting the thing? 2008 RRS HSE Stornoway Grey
Post #551107 Mon Mar 12 2018 2:07pm
Scrumpy
I got one of these Co-Pilot CPDVR3 Full HD 1080p LCD Rear-View Mirror Car Dual Camera Dash Cam which fully covers the rear view mirror and has nice 3" screen within mirror which is switchable between forward camera, rear view camera or both.
It also comes with a rear camera which, if wired into the reverse light will switch the mirror to rear view and plenty of cable.
The first one I bought from Tesco petrol station for about £30 and hard wired it into the courtesy light using a step down converter to 5v which cost about £8.
If you're going to hard wire the dash cam it's important to know the voltage of the unit as many of them are 5v and your car's 12v supply will fry them, hence the step down convertor.
However, after a leaky sunroof and heavy rain after about 6 months it shorted the step down convertor and blew the dash cam, not the cameras fault!
The second one I got was on Ebay as Tesco had sold out and it cost £39 but this one felt a bit like a "second" as the mirror part was not very clear but I've lived with it.
However, I do like the functionality, options and look of this unit and to be honest the price is pretty good too.
Hope that helps. 2016 RRS SVR Estoril Blue
Post #551108 Mon Mar 12 2018 2:09pm
phillh
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
+1 for the Nextbase, very impressed with mine Thumbs Up
Post #551109 Mon Mar 12 2018 2:11pm
Bill Portland
very easy. it's plugged in to the cigar lighter socket in the centre console (switches itself on and off when I unlock or lock the doors) and I've run the cable all the way around the glove box, and up the A pillar and across to the rear view mirror area. the cable just tucks in nicely without have to use any fixings. Merc C220 estate Sport AMG
Alfa GT
Rover 76 V6
Post #551110 Mon Mar 12 2018 2:42pm
Richythepom
Thanks Scrumpy. Yes it does help - interesting option that one - saves obscuring some of the windscreen... 2008 RRS HSE Stornoway Grey
Post #551111 Mon Mar 12 2018 2:47pm
Richythepom
Love the sound of this! I think this one's looking like a winner. Thanks all.
Post #551112 Mon Mar 12 2018 2:49pm
Eaters
Richy - if you've not yet handed over the dosh, you may want to have a browse through this ...
http://www.rrsport.co.uk/forum/topic45687.html
Might give you a bit more options to consider Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #551132 Mon Mar 12 2018 6:28pm
Richythepom
Thanks for this. No dosh handed over yet, so still considering the options. Costco are doing the Cobra IP200 for £40:
https://www.costco.co.uk/Electronics-Compu...m/p/252334
So I'm considering getting the Cobra and hard-wiring. I'm definitely no spark though, so I'm looking through the forum for dummy's guides! Lol 2008 RRS HSE Stornoway Grey
Post #551133 Mon Mar 12 2018 6:32pm
Eaters
I am always dubious about dabbling with electrics especially on the RRS where is can be so temperamental. However it was relatively straightforward to hard wire. In the link I sent you I supplied some pictures of my use of the fuse box behind the glove compartment which I think I got from someone else on the forum. As long as you have purchased the right stuff (e.g. piggy back fuse) and take it steady, you should be fine.
I went for a quite expensive dash cam with parking recording and 2 cameras but I am sure that there are some good ones out there much cheaper. I would suggest that you go for the best day/night camera you can afford as you don't want to go to all the trouble and expense of installing it only to find that when you need it, the picture quality isn't good enough to help. Robin
Gone:
MGZTT 190 2.5
Post #551135 Mon Mar 12 2018 6:41pm
Richythepom
Thanks Eaters. I've had a look through the link you sent and the pictures of the fuse box etc...
I gather you need to run the wiring from the dashcam, then along the edge of the windscreen, down the windscreen edge uprights and then somehow past the dashboard and into the glovebox to get to the fusebox, where the piggy back fuse comes into play. Is that the gist of it? 2008 RRS HSE Stornoway Grey
Post #551137 Mon Mar 12 2018 6:58pm
Cymruambyth
Wales
This is mine https://www.carcamcentral.com/review/viofo-a119-review I like this one cos of the wedge shape, very sleek, stealthy look. As far as fitting, auto electrician...£30 Not worth the hassle doing it yourself. Steve.
Post #551143 Mon Mar 12 2018 8:12pm
Eaters
Yes that’s it. But the wire can actually be hidden behind headlining and A pillar covers. I think I had a quick search on Youtube for videos on how to remove trim, and even purchased a set of trim tools (not expensive and subsequently often useful for other jobs). Trim fixings were a hidden world to me until this. Still no expert but I’m getting better. And once you decided that the worst that can happen is you break a clip and need to get a replacement, then you get more confident to have a go. And of course you’ve got the experts on the forum to support you if required. Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #551150 Mon Mar 12 2018 10:54pm
Richythepom
Thumbs Up Thanks! 2008 RRS HSE Stornoway Grey
Post #551181 Tue Mar 13 2018 8:38am
