![]() | Home > General > Croatian pirate offers reward / TDV8 needs your help!! |
So they fixed the broken diff so they say and the noise came back and then you found the prop was knackered or did they just leave it loose when they repaired the front diff i think it may have been the front prop may have been the issue as i have just had to replace mine and apparently its common on these cars so the prop shaft specialist said |
lunaroid Member Since: 18 Apr 2017 Location: Zagreb Posts: 17 ![]() ![]() ![]() |
Well, they claim they did repair the front diff - problem is, there was nothing wrong with it...it was the prop shaft all along...the sound and the symptoms did not change at all before after their "work".
Break their knee caps |
Cymruambyth Member Since: 27 Feb 2017 Location: North Wales Posts: 1533 ![]() ![]() |
I think that`s what extreme violence "local speciality" means Rob |
Thanks for your feedback,
No idea about the pic. I just saved it to my Chromebook and then rotated it there. Steve. |
If the photo is saved in your gallery then there is an editing tool that allows photos to be rotated and resaved back to the gallery for posting. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
N60613 Member Since: 24 Jun 2016 Location: capljina Posts: 32 ![]() ![]() |
lunaroid, if you need any help I'm 6'4 full of muscle with ugly face and not to far from you. Jokes on a side, can you give me details for the British LR shop in Zagreb please.
jim4244 Member Since: 16 Feb 2012 Location: No Posts: 1210 ![]() ![]() ![]() |
It sounds to me that all they may have done is changed the oil in the front diff and added a friction modifier to try to give the impression that they have physically changed mechanical components?
Hi Nino,
Hi Jim4244,
Hvala Bojane, beers are on me if get to Zagreb. cheers |
