Home > Wheels & Tyres > Fitting 275/45/20 tyres
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Looking to replace my tyres, heard that replacing the 275/40/20 tyres with 275/45/20 tyres give a better ride ?, would I need to have the Speedo adjusted or any problems with the tyre rubbing etc with standard set up ?, or should I just stay with the standard size?, thanks for the advice 👍🏻
Post #548999 Sun Feb 18 2018 7:28am
dobbo9
I'd be interested in this too...The 275/40/20 feels a tad harsh to me.
Post #549000 Sun Feb 18 2018 7:36am
Camelrock
275/45/20 is the way to go no mods required and no speedo issues. I’ve been running that size for years. I changed my spare for a match wheel/tyre as well. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #549001 Sun Feb 18 2018 8:27am
PC76
I have just fitted the 45 profile speedo is now only 1mph out at 70 when compared to the GPS. No issues with access height but not deflated the corners to check if any issues but you wouldn’t be driving it that low anyway.
I went for the General tire AT3 so 50/50 on off road as I’m currently building remote sites up in Scotland and sometimes have to go on site visits... if you go for these the tyre pressures are critical for a comfortable ride but standard settings seem to be the best so far. No uneven warring and good handling on tarmac. Not pushed them off Road yet just a few fields and snow but all good so far.
Post #549007 Sun Feb 18 2018 8:57am
paul2415
Ok thanks guys, looking to put a set of hankook ventus st m&s, had these on my last rrs running 275/40/20 tyres, any different in Corning at speed? Thanks
Post #549020 Sun Feb 18 2018 11:29am
paul2415
My spare is a 175/80/ r19, so would need replacing? As not much room under the rear to fit a larger diameter spacesaver wheel, recon 15mm before it would foul the box section of the bumper😳
Post #549021 Sun Feb 18 2018 12:08pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
We have the Hankook Ventus 275/45/20 fitted. Great tyre & Much improved ride.
Post #549034 Sun Feb 18 2018 1:35pm
There is sufficient room underneath to fit a full size spare with a 275/45 x 20 tyre without to much trouble.
Post #549084 Sun Feb 18 2018 7:50pm
RESSE
We need to replace our 275/40 20 tyres shortly - if I have read correctly changing to a 45 profile doesn't cause any issues?
Post #549427 Thu Feb 22 2018 9:44am
I ran 275/45 x 20" for several years, now run 275/45 x 21" and have had absolutely no issues what so ever, the difference in speedo reading is also negligible in fact if anything it is more accurate.
Post #549433 Thu Feb 22 2018 10:20am
RESSE
Wow, what a transformation!
I had a set of 275/45 20s tyres fitted this afternoon and the RRS is transformed - the steering feels more accurate, car feels more 'planted' on the road and so much quieter. Thumbs Up
Thank you rrsport.co.uk for the advice/help Bow down
Post #549929 Tue Feb 27 2018 6:26pm
Scrumpy
Sounds like it’s worth doing?
I might do the same when my tyres need replacing.
Just a thought, do you need to inform your insurance as I’m assuming they are changing from original spec? 2016 RRS SVR Estoril Blue
Post #549992 Wed Feb 28 2018 12:25am
RESSE
I informed my insurance company (Admiral) who made a note on the policy but other than that nothing else needed to be done.
Post #549993 Wed Feb 28 2018 12:45am
chaps, are there any other higher profiles that one can fit to the 20" wheels? --
Post #550006 Wed Feb 28 2018 10:03am
Scrumpy
Thumbs Up Thumbs Up 2016 RRS SVR Estoril Blue
Post #550022 Wed Feb 28 2018 1:20pm
