Home > General (L494) > SVR Light Load Tyre Pressures
GJW1
What tyre pressures do you run on the 22" Wheels.
My front is set at 40psi which I think is to high based on what the computer says but interested to see what others are running with more experience than me on this kind of thing.
Post #549506 Fri Feb 23 2018 12:27pm
Tyrefitter
I usually run my fronts at 34 & rears at 37-38.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #549508 Fri Feb 23 2018 12:38pm
Black Bess
I would run around 40psi all round. It is a heavy car and they will wear nice and square then.
Post #549510 Fri Feb 23 2018 12:52pm
SVR575
the book says 34 front, rear 37. SVR 2018 in Santorini Black.
Post #549511 Fri Feb 23 2018 1:01pm
GJW1
Ive gone inbetween so 36 front and 37 rear.
hasn't solved my main issue but working on that with CS now so fingers crossed.
Post #549710 Sun Feb 25 2018 7:17pm
SVR575
Whats the problem GJW ? SVR 2018 in Santorini Black.
Post #549754 Mon Feb 26 2018 9:04am
GJW1
Car pulls to the left to make it go straight you need to hold the steering wheel at about 12.30 but if you let the wheel auto centre then it pulls left.
It’s more annoying than a bad problem but I reported it twice and was told no issue so I thought it was just road camber but had the chance to get a second opinion from another dealer who confirmed it does what I say but they can’t fix it at the dealer and it would need to be sent off to be done for me but I’m waiting for customer services to now tell me who will pay for this. Before booking it in.
Not sure exactly what they want to do with it but I want it sorted now as feel I’ve been fobbed off previously when it should have been sorted.
Post #549775 Mon Feb 26 2018 2:58pm
Black Bess
Without having seen it, of course, it sounds like the steering track rods need shortening on one side and lengthening on the other, because the current set-up is not placing the power assisted steering in the neutral position when the wheels are straight ahead.
That is what I would look for anyway. If that is the case, it is a simple fix. But of course there may be something I am not aware of.
Adam..
Post #549777 Mon Feb 26 2018 3:17pm
Hog
Netherlands 2012 Range Rover Sport SDV6 HSE Lux Buckingham Blue
indeed. to be more precise , it seems you need some proper toe settings RRS 3.0 SDV6 HSE Lux
RRS 3.0 TDV6 gone
LR 3 HSE V8 gone
DiscoveryII V8 Gone
Discovery 1 V8 Gone
Mustang Shelby
Alfa Guilia (classic)
Post #549783 Mon Feb 26 2018 3:40pm
SVR575
Hunter Alignment...
https://www.alignmycar.co.uk/?gclid=CjwKCA...hoQAvD_BwE SVR 2018 in Santorini Black.
Post #549785 Mon Feb 26 2018 3:54pm
GJW1
Thanks for that info guys I can make my own enquiries and get it sorted from one of those listed on the website link and fingers crossed they are as knowledgable as you Black Bess and Hog.
Post #549787 Mon Feb 26 2018 4:23pm
ikeysolomon
United Kingdom 2013 Range Rover Sport Supercharged Adriatic Blue
Any more input, can't seem to find the right balance.
Post #553481 Sun Apr 08 2018 10:08am
GJW1
I’ve not had time to get the wheel alignment sorted but I have a few spare days next week so will have to make an effort to get it sorted then.
Post #553490 Sun Apr 08 2018 11:03am
andymc
for the last year I've only ever used the recommended pressures from the info on the door pillar. No issues here. SVR with a few bits from Urban and Glohh
Post #553673 Mon Apr 09 2018 9:45pm
GJW1
4 wheel alignment done today it was a bit out but fixing it has made a big difference.
I guess the weight of the car and the state of our roads knocked it out at some point.
Post #554438 Tue Apr 17 2018 7:33pm
