Home > General (L494) > SVR Light Load Tyre Pressures |
I usually run my fronts at 34 & rears at 37-38.
Fri Feb 23 2018 12:38pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
I would run around 40psi all round. It is a heavy car and they will wear nice and square then. |
Fri Feb 23 2018 12:52pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
the book says 34 front, rear 37. SVR 2018 in Santorini Black. |
Fri Feb 23 2018 1:01pm |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 |
Ive gone inbetween so 36 front and 37 rear.
Sun Feb 25 2018 7:17pm |
Whats the problem GJW ? SVR 2018 in Santorini Black. |
Mon Feb 26 2018 9:04am |
Car pulls to the left to make it go straight you need to hold the steering wheel at about 12.30 but if you let the wheel auto centre then it pulls left.
Mon Feb 26 2018 2:58pm |
Without having seen it, of course, it sounds like the steering track rods need shortening on one side and lengthening on the other, because the current set-up is not placing the power assisted steering in the neutral position when the wheels are straight ahead.
Mon Feb 26 2018 3:17pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
indeed. to be more precise , it seems you need some proper toe settings RRS 3.0 SDV6 HSE Lux
Mon Feb 26 2018 3:40pm |
Hunter Alignment...
Mon Feb 26 2018 3:54pm |
Thanks for that info guys I can make my own enquiries and get it sorted from one of those listed on the website link and fingers crossed they are as knowledgable as you Black Bess and Hog. |
Mon Feb 26 2018 4:23pm |
ikeysolomon Member Since: 02 Jul 2007 Location: High Wycombe Posts: 60 |
Any more input, can't seem to find the right balance. |
Sun Apr 08 2018 10:08am |
I’ve not had time to get the wheel alignment sorted but I have a few spare days next week so will have to make an effort to get it sorted then. |
Sun Apr 08 2018 11:03am |
andymc Member Since: 04 Jan 2017 Location: london Posts: 127 |
for the last year I've only ever used the recommended pressures from the info on the door pillar. No issues here. SVR with a few bits from Urban and Glohh |
Mon Apr 09 2018 9:45pm |
4 wheel alignment done today it was a bit out but fixing it has made a big difference.
Tue Apr 17 2018 7:33pm |
