![]() | Home > Technical > Flat battery on friends drive...How can I lock the car? |
Bustanut Member Since: 19 Nov 2017 Location: Nottingham Posts: 71 ![]() ![]() ![]() |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
Buy a new battery.. |
Can you not lock the driver's and rear passenger doors manually from inside and then exit the vehicle and lock the front passenger door using the key in the emergency key hole?
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Can’t you use the emergency unlock facility using the key in the passenger side door handle. Manually lock the doors from the inside then exit via passenger door and lock that on the key. I’ve not tried this but my logic says it should work. Robin
