Home > Technical > Flat battery on friends drive...How can I lock the car?
eyespider
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Java Black
Hi my battery went dead on friends drive. Tried to jump it but no joy. I took the battery home to charge it up but the car remains unlocked. I know now one is going to drive away with it without a battery however would prefer to lock it. It wouldn't lock with the fob just kept beeping.
Can anyone help?
2010 TDV8
regards
Post #549527 Fri Feb 23 2018 5:18pm
Bustanut
Post #549530 Fri Feb 23 2018 5:36pm
PC76
Buy a new battery..
Post #549532 Fri Feb 23 2018 5:41pm
Paddi
Can you not lock the driver's and rear passenger doors manually from inside and then exit the vehicle and lock the front passenger door using the key in the emergency key hole?
The rear hatch won't open without power so that should be secure. 2008 MY Java Black TDV8 HSE
Post #549533 Fri Feb 23 2018 5:49pm
Eaters
Can’t you use the emergency unlock facility using the key in the passenger side door handle. Manually lock the doors from the inside then exit via passenger door and lock that on the key. I’ve not tried this but my logic says it should work. Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #549534 Fri Feb 23 2018 5:52pm
