Home > Technical > Rear offside suspension heigh/ issue one side/ slow to raise
paul2415
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Drove off the drive and put into normal height mode, 200mtrs down road dash showed suspension raising ?, all ok for 1 mike, dash showed only normal height suspension available, pulled over re started and lowered and raised all ok, went to have a new tyre fitted, upon start up dash warning, drove home ok, lowered and put to off toad height and dash shows suspension will raise when cooled down? Turned off and left 30 mins, put to normal height and the rear drivers side sits approx 25mm heigher, put into off road mode and dash shows cooling down required? Put a code reader on and got the codes below, no suspension codes though, any help appreciated 👍🏻
Post #549362 Wed Feb 21 2018 3:16pm
paul2415
Just tried it again, after starting Engine the dash asks you to confirm suspension height, if you put it in off road car don’t lift and the up arrow stays lit, rear of car heigh but front didn’t rise, ????
Post #549373 Wed Feb 21 2018 5:43pm
Socast
My money would be on a failing compressor.
Post #549420 Thu Feb 22 2018 9:15am
paul2415
That’s the outcome I’ve come to with other posts on here👍🏻
Post #549429 Thu Feb 22 2018 9:56am
