Home > General (L494) > Another engine failure
Page 5 of 6 <123456>
geoffsnook
As dm says the cranks are still braking on the newer models so what changes have been made are not doing what they intended and as on the other post in other countries its 10-15 % according to people who live there and its mentioned in this post as well Thumbs Up
Post #548747 Thu Feb 15 2018 7:35pm
Been-and-dunit
I have sent LR a email about this issue,let's see if they reply . It's a bit worrying when you have a L494 with 7 months left with warranty Big Cry
Post #548759 Thu Feb 15 2018 8:42pm
362bkr
United Kingdom 2012 Range Rover Sport SDV6 Autobiography Santorini Black
You will receive a reply saying they will deal with every claim in a case by case basis bla bla bla .........
Post #548760 Thu Feb 15 2018 8:56pm
Been-and-dunit
In other words F--- O-- will see if they reply let you know Whistle
Post #548761 Thu Feb 15 2018 8:59pm
drdelrrs
wilf wrote:
geoffsnook wrote:
https://www.iol.co.za/motoring/cars/land-rover/unease-grows-over-land-rover-engine-1925479 Thumbs Up
Interesting that the source you quote is talking about pre 2012 engines only:
“The issue affects only 1.3 percent of Land Rover engines sold in South Africa over the past 10 years,” she said.
“Changes have been made at a production level and all new engines manufactured since 2012 use a new bearing design"
So what is happening with m roe recent engines? Is it just a "normal" failure rate? Same as any other marque suffers from? (All mechanical things break to some degree)
This might be ALL their engines, only crankshaft failure and not the just V6 diesels so the proportion of the V6 diesel 'might' be much higher!
Post #548791 Fri Feb 16 2018 9:35am
KieRRSAB
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Siberian Silver
March 2015 AB v6 diesel - 80,000 miles and engine fails, fortunately covered under manufacturer’s warranty. Main dealer has been excellent providing a courtesy RRS, however, they have been unable to explain what went wrong as entire engine unit has to be returned to JLR. Approvals for new engine and engine harness authorised very swiftly by JLR - should get car back in next 7 days, unfortunately I only have just over 1 month remaining on warranty.
Post #548886 Fri Feb 16 2018 9:57pm
A new engine from LR will come with two years of warranty anyway, irrespective of any vehicle warranty. 2012 SDV6 - it's missing a couple of cylinders
Post #548893 Sat Feb 17 2018 12:24am
Disco_Mikey
It is actually only warranted until the end of the original warrany period...
So that brand new engine only has a month warranty...
Post #548901 Sat Feb 17 2018 7:22am
Really? All LR parts fitted by a LR dealer are covered by a two year warranty of their own. Why should an entire engine be any different? 2012 SDV6 - it's missing a couple of cylinders
Post #548912 Sat Feb 17 2018 10:47am
SVR575
15k for a new engine i would expect at least a two year warranty from when fitted. Evil or Very Mad SVR 2018 in Santorini Black.
Post #548915 Sat Feb 17 2018 11:13am
362bkr
Is it that if it’s paid for by the warranty then it’s only guaranteed till the end of the warranty ?
Post #548916 Sat Feb 17 2018 11:14am
Disco_Mikey
Correct ☝️
Post #548928 Sat Feb 17 2018 12:50pm
KieRRSAB
The bill with the engine harness is closer to £30k and the warranty expires in 1 month.
Post #548929 Sat Feb 17 2018 1:08pm
SRE
Spain
Question for Disco_Mikey
Mikey, can you tell us what you would charge to source and fit a used engine, (typical cost) This info may be of use to quite a lot of forum members. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #548931 Sat Feb 17 2018 1:18pm
Disco_Mikey
Never fitted a used 3.0, due to them Censored themselves so often...
2.7 replacement is £4.5k inc new oil pump and belts while it’s in bits
A 3.0 replacement would be around £7k
Post #548978 Sat Feb 17 2018 8:01pm
