![]() | Home > Maintenance & Modifications > Range Rover Sport 2010 onwards DRL modification |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 ![]() ![]() |
I am looking to run my LED rings on my 2011 Sport as DRLs.
Thanks Andy.
Not a Auto Electrician, but had a look at wiring diagram and there is no specific mention of the DRL's however it does mention s/lights obviously. This appears to be a Red and Black wire Pin No. 2 in the L/H headlamp plug Red and Orange wire on R/H lamp plug top row centre pin, there is also a red and black wire Pin No. 14 which could well be a ignition live as it states IGN. and comes from a 5amp fuse No.50 in the CJB.
Good spot on pin 14 being Ignition.
I think it may have been Pin 14 I used as ignition live when I fitted DRL's to my old 09 plate sport, but it was a few years ago now. It was certainly in the headlamp plug somewhere that much I can remember.
Possibly might work then if run a wire from pin14 straight to ignition live spare fuse slot in fuse box as already earthed.
Using the Gap IID BT Tool you can alter sidelights to run as DRL automatically, so couldn't you just turn that on and then run from a sidelights lead or sidelight fuse in fuse box? John
Pin 14 is already a ignition live which you could use to work DRL's.
Nice thought mate, unfortunately I don't have access to an IID BT tool |
I don't know whether this would work or not as I said not a auto electrician, in the headlamp plug Pin 14 is an ignition live, Pin 2 is the sidelight, if you link Pin 14 to Pin 2 that should power up the sidelight when ignition switched on according to my reckoning but as said not an electrician, however haven't a clue what would happen when you actually turn the lights on, might have to fit a diode in the circuit somewhere. The other thing is may also turn the rear light on as, in which case you may as well simply drive with sidelights on all the time. I am not suggesting you try this as I don't know if it would work or not or cause any other electrical problems, short circuit etc. it is only a thought.
I have now started looking at other ideas, for example a DRL strip inside the headlights, then wired up separate from the headlights to come on as a true DRL.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
The adapative cruise wiring loom just above the horns (if your car does not have adaptive cruise control) can be used as the ignition on wire as shown on the picture below (not my car).
Why not just turn the side lights on when you get in the car? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
DRL's are much brighter than side lights. |
