Home > General (L494) > CTEK Battery Sense & CTEK MXS5 |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Hog - you originally wrote that experts say not to use recon mode. Which experts are you referring to? I have posted a link where recon mode is recommended a couple of times a year only. Anyway, lindab’s electronics weren’t fried by recon. A colleagues FFRR has been on recon a few times. Mine will be on recon and float for a week. Will report back. 2022 P440e AB |
Tue Feb 06 2018 11:03pm |
Nice one... Still odd, that they have an AGM Recond mode but advise not to use it.
Wed Feb 07 2018 12:52pm |
Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 904 |
Exactly, who knows Anyway I have now changed mine over to Car+AGM
Wed Feb 07 2018 1:09pm |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 |
Txs for clearing this up Lindab. I was at the point of reacting to Paul that JLR even don't recomment AGM charging.
Wed Feb 07 2018 4:24pm |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
Yes thanks for clearing this up I also use the comfort connector with LED's which is extremely handy, but I've noticed that in cold weather that even though the charger is showing green so has complete it's charge, the LED indicator changes to amber pretty soon after disconnecting - do you find this? I'm aware of temperature effects on batteries, but I'm thinking that comfort connector green LED must be set for a fairly high voltage. I normally find it indicating red unless having just switched off the engine. I also have the CTEK Analyser but have not yet tested the RRS battery, it needs direct battery terminal connection so I've been avoiding disconnecting it from the RRS, but it's a reasonably new battery so I expect it to show good results (I'm guessing it must work by measuring battery internal resistance then using the battery value you input to do it's calculation, so unless direct clamp connections it usually shows a bad result). Dennis 13MY Range Rover Sport Autobiography SDV6 - mine 14MY Range Rover Evoque Dynamic SD4 Black Pack - wife's 99MY Defender 90 TD5, Soft Top Conversion - my toy, and bairns favourite |
Wed Feb 07 2018 5:24pm |
Dennis, https://smartercharger.com/faq
Wed Feb 07 2018 6:51pm |
Fletcher Member Since: 28 Jan 2015 Location: Devon Posts: 481 |
Hi all , I’ve bought a 2014 discovery 4 as a run around, the rrs is getting used even less now , I’ve got my eye on a ctek 7.0 am I right in thinking it won’t be any good plugged into the cigar lighter , I will have to connect to the terminals under the bonnet.
Mon Feb 12 2018 12:56pm |
Part 2 . How are you guys connecting to the poles/spiked terminals on the car . I was hoping they would be threaded so a couple of nuts would do the trick with the ctek eyes rather than the crocodile clips.
Wed Feb 14 2018 12:12pm |
Fletcher, See my post above. Put the eyelets on, fit jubilee clips holding them down hard on eyelets as you tighten them. They have nuts to tighten not worm drive. You will have to cut a bit out of the plastic cover on positive side to clear eylet. Stanley knife is fine |
Wed Feb 14 2018 12:20pm |
Thanks, I spend a lot of my time in “man mode” the state of mind where I cannot read, count or talk. Just need to be told stuff. 👍 |
Wed Feb 14 2018 10:56pm |
Kens96 Member Since: 01 May 2016 Location: London Posts: 6 |
Hi, my RRS sits unused during the week and so I am going to get a MXS5. I am aware that there are two batteries in the boot. If I connect directly to the main battery under the spare and leave it on charge will that keep the second smaller battery charged too or do I need to swap it over to the smaller one now and again?
Wed Mar 14 2018 11:12pm |
Though I charge the front bonnet battery, I believe that the both are charged in series.
Sat Mar 17 2018 8:24am |
Update post AGM Recon
[/img] 2022 P440e AB |
Sat Mar 17 2018 8:30am |
