Home > Technical > RRS tdv8 right turbo noise from variable
torcida1950
Croatia 2010 Range Rover Sport TDV8 HSE Adriatic Blue
Hello everyone.
I have problem with right turbo.
Sound comes from variable.
Put both New turbos and sound is same on right side with old and New turbo.
I opened old turbo and didn’t find nothing Strange inside.
Oil pressure is fine, all conections is fine, Cat converter ok, egr ok....
Post #543314 Wed Dec 13 2017 1:12pm
Paddi
That IS weird.
Sorry no experience of anything like that. If you are lucky the Disco--Mikey resident Land Rover guru will see this and offer a possible explanation. 2008 MY Java Black TDV8 HSE
Post #543321 Wed Dec 13 2017 8:52pm
lunaroid
Croatia 2009 Range Rover Sport TDV8 HSE Buckingham Blue
Hi Torcida1950
Have you fixed it?
What was it? Is there someone in Split doing Land Rovers?
Regards from TDV8 from Zagreb Wink
Post #544533 Mon Jan 01 2018 7:00pm
torcida1950
No, tomorow will try to do few things before I move cabin.
Here in Split , there is no service of Land Rover .
In ZG there is Benussi , but this problem is so strange and no one has it.
I’ll fix IT, but dont know when. Laughing
Post #544536 Mon Jan 01 2018 7:30pm
lunaroid
OK, good luck!
There are couple more independent Land Rover workshops in Zagreb, for now I did not need any...something tells me this is going to change sooner or later Sad
Post #544562 Tue Jan 02 2018 8:27am
torcida1950
Fixed !!!!
Post #545204 Mon Jan 08 2018 5:42pm
lunaroid
Cool! Congrats!
What was it / how? Smile
Post #546521 Tue Jan 23 2018 12:15pm
OceanCarl
Spain
torcida1950 wrote:
Fixed !!!!
I have the excact same noise from the right side of my engine bay on my 2007 RRS TDV8. It varies in different rpm's. Getting worse these days. not so often when engine is cold, but constantly when warm.
Please tell me what it was and what you did to fix it?
-Carlos
Post #546751 Thu Jan 25 2018 6:56pm
torcida1950
Hi to everyone
Problem was in exhaust branch on cylinder head.
IT was deformed.
I put New gasket and New nuts, but didn’t checked deformations on base of exhaust branch. Big Cry
After I settled the base and put IT all together , everything is working fine.
This car destroyed me, menatl and physical health in worst time of the year.
But now I need 2.30h to remove and 3.30h to compose all together By my self, without any help.
Post #546759 Thu Jan 25 2018 7:24pm
OceanCarl
Spain
Thank you for that quick reply..
Unfortunately it was as suspected, and most probably, I have the same problem Sad
Post #546763 Thu Jan 25 2018 7:47pm
torcida1950
Due the gas leakage, a turbo variable Go Crazy and make noise.
Every time you remove exhaust on head,
it is necessary to measure defomation and align if necessary.
Greetings from sunny Split-Croatia
Post #546764 Thu Jan 25 2018 7:49pm
