![]() | Home > Tips & Tricks > Disabling keyless entry- it works!!!! |
Not sure if this works with our cars but there has been success over on the Disco forum, considering the number of cars being stolen recently using keyless signal boosting I thought it was worth a post over here |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
+ 1 Great tip |
Great tip & saved me £300 fitting the Ghost Autowatch.
Just tried on my14 RRS,,it works but you need the ignition on for it to work |
hafman Member Since: 16 Oct 2016 Location: West Sussex Posts: 92 ![]() ![]() |
At the risk of exposing my stupidity, I thought that using keyless entry / exit was more secure than using the fob buttons, as no radio waves can be caught / cloned. |
That true but I'm hoping they cannot clone it when near car to open it,,if you get my drift.
d-9 Member Since: 10 Jan 2017 Location: Wiltshire Posts: 317 ![]() ![]() ![]() |
How do you think the key talks to the car? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
I never use the Fob to Lock or Unlock the car, as I thought I read some where that if you use the door handle buttons then no radio signal is transmitted, but could be completely wrong on that.
Unless you physically put a key in the hole and turn it, the key has to be talking to the car with some kind of wireless radio magic. |
Correct. However, I believe (and I may be wrong but I read it on this forum) when using the buttons on door handles the radio signal is very weak, much lower range. A thief would have to be standing right next to you to clone that one. Like hafman, I am also unsure whether using the key fob buttons instead of the door handle buttons is a good idea when you’re, say, in a car park with someone waiting nearby to clone the signal. At home, I avoid leaving the keys close to the driveway to minimise the risk that keyless entry exposes us to. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond Last edited by fkarim on Sat Jan 20 2018 10:24am. Edited 1 time in total |
"Correct. However, I believe (and I may be wrong but I read it on this forum) when using the buttons on door handles the radio signal is very weak, much lower range. A thief would have to be standing right next to you to clone that one."
Dobby Member Since: 02 Jan 2018 Location: East Seaxe Posts: 102 ![]() ![]() |
My local dealer carried out THIS fix on mine. They made sure only two keys were programmed to the car, and also said the 'modification' mentioned in the link prevents the keyless relay attack. |
