Home > General (L494) > Spare wheel - full size possible under boot tray? |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 |
I was going to check, but presumed the rolling diameter would be the same for them all, and the 22" would have thinner rubber? |
Wed Jan 17 2018 8:57am |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Rolling diameter of both the 275/45/21 and 275/45/22 tyres is 1.9% smaller than the 295/40/22 tyres. |
Wed Jan 17 2018 5:17pm |
Thanks Phil. How does the space saver compare? |
Wed Jan 17 2018 5:36pm |
I assume the reduced size wheel has the same circumference as the 21/22 - i.e. 1.9% smaller than the SVR 22 wheels. You wouldn’t want to drive with odd sized wheels. The TC and ABS would have heart failure. |
Wed Jan 17 2018 6:31pm |
So my options are tyre sealant or a low loader? |
Wed Jan 17 2018 6:51pm |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 |
No you need a reduced size spare, which is the no cost option for the SVR. SVR 2018 in Santorini Black. |
Wed Jan 17 2018 7:05pm |
Forgive me I'm confused with the contradictory comments regarding the reduced section wheel and I've yet to figure out a part number or seen one for sale (can't order as option as bought used)
Wed Jan 17 2018 7:29pm |
Reduced section alloy spare wheel
Wed Jan 17 2018 7:41pm |
I thought I was confused before, but I'm more confused now. Via the new car config, the reduced section wheel seems to be what I thought was (and is widely advertised on eBay as) a space saver.
Wed Jan 17 2018 8:25pm |
Yes!
Wed Jan 17 2018 8:32pm |
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 871 |
My wheels are standard 22 inch with 275/40 tyres and they fit. I am assuming they run on a 10 inch rim. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
Wed Jan 17 2018 9:39pm |
Wed Jan 17 2018 10:24pm |
And let the other tyres down and drive slowly |
Thu Jan 18 2018 7:39am |
DaveW Member Since: 14 Nov 2013 Location: Warwickshire Posts: 283 |
You're on a 9.5J rim. 10J is SVR specific Its the 295 tyre width, not the OD that prevents the floor sitting down on the SVR 22's |
Fri Jan 19 2018 11:09am |
