![]() | Home > General (L494) > Spare wheel - full size possible under boot tray? |
MrM Member Since: 16 Jan 2016 Location: London Posts: 146 ![]() |
I was going to check, but presumed the rolling diameter would be the same for them all, and the 22" would have thinner rubber? |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1675 ![]() ![]() ![]() |
Rolling diameter of both the 275/45/21 and 275/45/22 tyres is 1.9% smaller than the 295/40/22 tyres. |
Thanks Phil. How does the space saver compare? |
I assume the reduced size wheel has the same circumference as the 21/22 - i.e. 1.9% smaller than the SVR 22 wheels. You wouldn’t want to drive with odd sized wheels. The TC and ABS would have heart failure. |
So my options are tyre sealant or a low loader? |
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
No you need a reduced size spare, which is the no cost option for the SVR. SVR 2018 in Santorini Black. |
Forgive me I'm confused with the contradictory comments regarding the reduced section wheel and I've yet to figure out a part number or seen one for sale (can't order as option as bought used)
Reduced section alloy spare wheel
I thought I was confused before, but I'm more confused now. Via the new car config, the reduced section wheel seems to be what I thought was (and is widely advertised on eBay as) a space saver.
Yes!
IRBails Member Since: 22 Nov 2013 Location: Wollongong Posts: 872 ![]() ![]() |
My wheels are standard 22 inch with 275/40 tyres and they fit. I am assuming they run on a 10 inch rim. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW. |
And let the other tyres down and drive slowly |
DaveW Member Since: 14 Nov 2013 Location: Warwickshire Posts: 283 ![]() ![]() |
You're on a 9.5J rim. 10J is SVR specific Its the 295 tyre width, not the OD that prevents the floor sitting down on the SVR 22's |
