![]() | Home > Faults & Fixes > air suspension front leaking |
glennp123 Member Since: 04 Dec 2017 Location: n.ireland Posts: 36 ![]() ![]() ![]() |
Did you check around the tops of the bag units? They may have been rubbing at an angle through time. |
scousefly Member Since: 25 Jan 2015 Location: sheffield Posts: 248 ![]() ![]() ![]() |
of mine has had the same issue on their 07 2.7. After much dicking about they found an issue on an American site which talked about a micro peppering issue on the air reservoir box under the passenger side door. It held during a pressure check but as the holes were so small it let air out overnight |
