Home > Faults & Fixes > air suspension front leaking
enlund27
Finland 2006 Range Rover Sport TDV6 HSE Rimini Red
rrs 06 bought it in the summer noticed directly that the front was in acsess height in the mornings. but directly when i started the car it came up to standard height. but now the yellow varning light comes on after a couple of hours because it has lowered itself in the front not all the way down to accsess height gradually sinking. thougt it would be the front valve block. changed that no diffrence. the compressor is only one year old and the same for the shocks. tryed remowing fuse 26 over night slightly lower in front right. tryed soaping the front valve and shock no bubbles. when i clear faultcodes with nanocom it comes back to normal height and yellow light goes away for a couple of hours. getting fault codes: C1A13 , UO132 , UO421. but i dont understand what that got to do with the front sinking!!! ideas?? airleaks? shocks leaking?
Post #545869 Sun Jan 14 2018 6:48pm
glennp123
United Kingdom 2007 Range Rover Sport TDV8 HSE Firenze Red
Did you check around the tops of the bag units? They may have been rubbing at an angle through time.
Post #545991 Mon Jan 15 2018 6:59pm
scousefly
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Sumatra Black
A friend
of mine has had the same issue on their 07 2.7. After much dicking about they found an issue on an American site which talked about a micro peppering issue on the air reservoir box under the passenger side door. It held during a pressure check but as the holes were so small it let air out overnight
Post #546062 Tue Jan 16 2018 10:27pm
