![]() | Home > In Car Electronics > RRS NO HEAT..HELPPPP |
phillh Member Since: 09 Oct 2016 Location: Hertfordshire Posts: 198 ![]() ![]() ![]() |
Q1 - Is your coolant level OK?
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 ![]() ![]() ![]() |
Hi Phil
GodivaNige Member Since: 14 May 2016 Location: Warwickshire Posts: 420 ![]() ![]() |
Don’t go jumping in changing a heater matrix until you’ve determined whether the climate control flaps are operating correctly, in particular the air mix flaps. The directional flaps are simple to determine correct operation by feeling for air coming from the vents you expect, when selected. The air mix flap not so easy to determine as it is finely controlled by the CC ECU depending on what signal it is reading from the cabin sensors
The thermostat was the first thing I changed and not made any difference once changed.
Gdyeomans Member Since: 31 Oct 2019 Location: Birmingham Posts: 3 ![]() ![]() ![]() |
How did you get on?
Heater matrix sorted the issue mate I did it myself. |
Duc750 Member Since: 27 Mar 2019 Location: Northampton Posts: 158 ![]() ![]() |
Is it Petrol or diesel ?
