Home > Technical > tailgate glass switch
Gandalf
My tailgate glass switch has stopped working took out the switch sprayed it with contact cleaner tested it with my meter and the switch is completing the circuit. So I'm at a loss now so what else could it be.
Peter If it ain't broken down it soon will
Pulling my Vanmaster tin tent with my 2005 RED RRS HSE TDV6
1973 Land Rover Series 3 110 safari Gone but not forgotten
1990 Discovery 200Tdi Gone thank god
1996 Discovery 300Tdi sadly missed
2003 Discovery TD5 Gone to LR heaven
2004 Discovery TD5 Gone to Aberdeen hope it likes it there
2005 RRS HSE Rimini Red (my Disco 3 in a posh frock) sadly selling
Think I see a pattern here
Post #544764 Thu Jan 04 2018 10:47am
broken wire in the rubber boot at the top of the tailgate maybe ?
pink wires maybe ?
Post #544774 Thu Jan 04 2018 12:40pm
Gandalf
Cheers Andy will have a look when it stops peeing down hang on this is Bacup rain is normal weather Laughing , just hope it's not the lock god know how I'd get it out with the door closed Banging Head If it ain't broken down it soon will
Post #544779 Thu Jan 04 2018 1:46pm
Gandalf
Stopped raining so went out and checked if there was power to the switch socket nothing, there are three rubber boots which I assume are for the wiring/screen washer so which one has the wires I want to check.
Post #544861 Fri Jan 05 2018 11:08am
Tim in Scotland
It is common to find the upper section release rubber has perished so while you are dismantling things it may be worth replacing yours, there is also a problem with condensation between the plastic inner and outers of the upper tailgate that runs down inside them and settles in the release switch. Both my 2.7 and 3.6 RRS’s suffered with the failure of the switch and both upper sections were replaced under warranty. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #544862 Fri Jan 05 2018 11:41am
I doubt you will see 12v at the switch.
You need to remove the rear spoiler. (3x 10mm plastic nuts and 2 big torx)
But urrr you need to open the glass bit for that Surprised
The middle tube has the wires to the glass bit. and release switch
The right side, the washer tube
The latch release is on the left tube
If you have an IID tool, you might be able to activate the latch, thus gain access to bolts and prove the actuator part is ok.
Otherwise I guess you might need to remove the C pillar trim inside (left side)
And maybe pull the headlining down at the middle (its secured in the middle, pull the metal bit down with a long screwdriver in 2 places)
and hunt for the appropriate wire, which won't be that easy.
Post #544864 Fri Jan 05 2018 11:46am
Gandalf
Ah so an iid tool might help. I've ordered one from Dan he's running a group buy on the D3 forum so I'll wait for that. Cheers If it ain't broken down it soon will
Post #544865 Fri Jan 05 2018 11:51am
Not sure if it can do it.
I will try and remember to have a look.
Post #544867 Fri Jan 05 2018 12:00pm
Had a look
Can't see it in my version of the app Neutral
Be nice if they added functions to do the 2 rear latches.
Looks like you will have to do it the hard way
Post #544880 Fri Jan 05 2018 2:26pm
Gandalf
Censored I'll live with it for now, got another problem now the top fixing that holds the tailgate damper has sheared Banging Head have a set of esi-outs so will tackle it tomorrow. I love landrovers I never get bored Laughing thanks for looking anyway Andy Thumbs Up If it ain't broken down it soon will
Post #544881 Fri Jan 05 2018 3:09pm
Gandalf
Well found out why the pivot bolt has sheared the Censored damper had seized good job it didn't rip a hole in the body work. ordered a new pair to be safe plus they are handed Rolling Eyes If it ain't broken down it soon will
Post #545129 Sun Jan 07 2018 9:26pm
